auto mechanic looking for another mechanics advise.....
  • lee_dutcher
    • Apr 2009
    • 822
    • mason city iowa
    im working on a 02 kia sportage 4x4 has 2l engine......ok her the problem....
    hooked up code scanner pull 2 codes
    bank 1 #1 cylinder running lean
    bank1 knock sensor
    ok when i take it apart i see 2 sets of injectors 2 green which are in the rear of the motor and 2 orange which are in front of motor.....well clylinder 1 and 2 are green and 3 and 4 are orange......which one need to be replaced....the front cylinder the book says it is #4 or the very back injector which is green....but what confuses me is that useally when i work one rwd 4 clinder car/ trucks it goes frome the to 1234 not from the front 4321.......firing order is 1432...i think if remember rite.... plz any impute would be greatfully appricated
    1980 gs1000g "stock"
  • cywelchjr
    XS-XJ Super Guru(Deceased)
    • 4450
    • Sacramento, CA
    Unless the injectors are unique and different for each cylinder you should be able to replace the one and if nothing changes put the old one back in and put it in the front one.
    • XSokieSPECIAL
      • Jun 2009
      • 1631
      • Tulsa, OK
      bank1 knock sensor
      Lee,
      The first thing I would do is look for is vacuum leaks around the runner for #1. Any loose ,cracked , or broken vac.hoses. Also check for intake gasket leaks.
      These are the two most likely culprits.
      Kia has an online troubleshooting and tech helpline. Search for it. I will get the address for the site from work tomorrow and post it for you.
      OK?
      • XSokieSPECIAL
        • Jun 2009
        • 1631
        • Tulsa, OK
        Kia Tech Site
        Lee,
        Here's the link to that Kia tech site.
        Just register and start searching. It's free.
        Good luck!
        • XSokieSPECIAL
          • Jun 2009
          • 1631
          • Tulsa, OK
          Sorry....... try it now.......http://www.kiatechinfo.com/index.asp
