Motorcycle exhaust Wrap?
  • digitalsam
    • Aug 2008
    • 208
    • Carlsbad, NM
    This is an odd question, but a friend told me that I need to wrap my exhaust with exhaust tape. He couldn't give a better reason than looks. I like the chrome exhaust but am curious why you would want to wrap a motorcycle exhaust? Heat in a car, stuffed under the hood, I can understand. But why on a bike? I have seen it most often on bobbers.
    Just a question.
    Sam Christensen
    The Chronicles of my Rebuild http://xs1100rebuild.blogspot.com
    If you are leading and no one is following, maybe your just taking a walk.
    Currently bikeless. Sold my 1980 XS1100 Special
  • 1st bike
    • Nov 2009
    • 258
    • indiana
    i don't know why you HAVE to, but i actually love the way it looks. I am going to try and put new pipes on my 80 xs1100, and wrap them, but that is about my last project....
    1980 XS 1100 Special (working to be my daily ride)
      • 7828
      You would wrap a bike exhaust too keep the heat off your legs, for the most part. The wrap will hold in the heat, and if you are running a turbo it will help a little with HP. A lot of people believe you need the wrap on a "hot" engine to help keep the engine cool.
      I think the wrap isn't that good looking, and it will not stay on that well if you ride like I do, year-round. I will try and get a ceramic coat on the exhaust system for my project. It will hold in the heat, and stay looking good even when it's been through a rain storm or five.....
      • randy
        • Dec 2003
        • 4521
        Why anyone would wrap a chrome exhaust, especially a new one is beyond me. I could see if it was ratty and rusted, maybe a wrap would be a cheap temporary alternative if replacement was too costly.
        • Ivan
          • Jul 2008
          • 2524
          • Hutchinson KS
          That stuff is just a cast you put on until your exhaust heals, so you don't have to re break it.
          Ich habe dich nicht gefragt.
          • cywelchjr
            XS-XJ Super Guru(Deceased)
            • 4450
            • Sacramento, CA
            In general I think that exhaust wrap looks stupid. Either get them re-chromed, painted or ceramic coated. I'm thinking of jet hot type coating for my Jardines, they have one available that looks almost like chrome.
            • xs11jack
              HALF GURU
              • Nov 2002
              • 606
              • O'Fallon, Mo.
              Sometime ago
              I was told that keeping the heat in the exhast pipe increases the horsepower in some way. There used to be a ceramic coating for the inside of the pipes that would increase the horsepower 10%. I can't remember the name of the company, but they catered mostly to the street rod people.
              J.D."Jack" Smith
              1980G&S "Halfbreed"
              1978E straight job
              "We the people are the rightful masters of both congress and the courts, not to overthrow the constitution, but to overthrow the men who pervert the constitution." Abraham Lincoln
              Life is like a coin, you can choose to spend it any way you wish, but you can only spend it once. Make your choices wisely.
              • 81xsproject
                • 3185
                • Fortuna, CA
                Your correct, hotter air has less flow resistance. Personally, I think it looks good on the right bike and plan on doing it to my SuperTrapp.
                '81 XS1100 SH
                Sep. 12th 2015
                RIP
                • TADracer
                  • 1417
                  • Kenner, Louisiana USA
                  I'm not much for the look of a wrap either but the idea is to keep the heat of the gasses inside the pipe.
                  Insulating the pipe with a wrap or a ceramic type coating holds the heat inside of the pipe and will slightly accelerate the exhaust gasses resulting in better scavenging during the exhaust stroke and during the valve overlap event. At least that is what Techline Coatings says and they supply the ceramic coatings to many of the header coaters.
                  I do know if you get your pipes coated at a Jet Hot dealer they blast and coat both inside and outside of the pipe.
                  Mike Giroir
                  79 XS-1100 Special
