Sorry to say that you sort of got hosed on the price of the battery. You can find them at most autoparts stores much cheaper as well. I am sure others have pointed this out but at idle, sometimes the charging system does not put out enough to charge the battery and it will slowly draw it down. When you get the bike going again, see if the headlight gets brighter when you rev the motor. If it does, the charging system is probably working correctly.
Also, these are air cooled motors. It is not a good idea to allow them to sit at idle for an extended period. You stated that you ran it for 3 hours, was that sitting at idle? If you need to do this for some reason, a fan blowing across the motor will help some.
And as Ken said, going through all of the connectors is a very good idea.
