It's Alive!
I'm stoked! I checked the wires, and the colors matched, but I swapped them anyways, and it started right up on the first try.
I've got a ticking noise that sounds like it's coming from the valves
, but it's idling smoothly and revs quickly, and I haven't even set the timing yet. The only issue at this time (other than I'm sure I need to adjust the valves, which I'll measure during the week and hopefully get the right shims next saturday), is that the clutch is not releasing. I'm pretty sure it's assembled correctly, and I think I finally have it adjusted right (took 3 tries to get the feel for it), but I can't stop the rear wheel in gear without killing the engine.
It also won't start in gear with the rear brake applied. I'll pull the side cover off again if I need to, but I'm hoping it's just stuck and that I'll be able to get it freed up. If not I may need to get some clutch parts once I figure out what's wrong. But it runs now.
