Tire pressure
Try going back a click on the rear shocks. I run mine on the third setting. Even with hard bags. Drop the pressure in small increments and find that sweet spot. Different tire compounds will make a difference.
I think the point that several of us were trying to make here is that it will be different for each bike and rider - there is not magic number that works for everyone. Tod was not trying to say that everyone needed to run fully hard shocks and max air pressure, just that that is what works for him.Harry
'79 Standard
'82 XJ1100
'84 FJ1100
Acta Non VerbaComment
It never happened........I don't want to say this actually happened, because some jerk will tell me that reality is subjective. Anyhow, during the next day's ride, it might have just happened that I started loosing tire pressure for what ever reason. Some might say that I was not able to take the corners nearly as fast with a spongy half inflated tire.
1980 XS11 Special - chopped, dropped and OCTY is still installed
 - NOW IT'S FOR SALE!  $1,800 OBO
Famous Myspace quote:
It's funny because I am from TEXAS!Comment
Beautiful Balloons...
Ok... I'll say that I run the max pressure in both front and back tires: 40 Psi. That's what's written on my Kendos. (Yup...the infamous Kendos...
Why the max? My train of thought is that these are not car tires. Car tires will wear unevenly if overinflated (bald in the middle) and if underinflated they will wear at the edges. The underinflation really shows itself when one looks at a set of tires on the front where they do the job of steering the car. Whatever tires one installs on a car generally they are load rated for the particular vehicle and sized appropriately so that the "contact" patch is the right length and width. In particular the over/under inflation shows up in the width wear pattern because the tire is supposed to have a "flat" profile where it contacts the road. One can do a "read" on these car tires and determine if in fact inflating them to a certain Psi is resulting in a less than optimum "contact" and then adjust the pressure accordingly. Standard operating procedures for the standard car tires which spend most of their life going in a straight line with occasional accelerations/decelerations and low speed curves/turns.
Motorcycle tires are a different animal altogether. The tires are not flat in cross section but rather have a rounded design in order to accommodate the "lean" angle needed to smoothly enter/exit a turn. (I confess that I look at people's rear tire to determine their riding style and I am somehow disappointed when I see the rear tire worn flat like it is installed on a Honda Civic....) Continued straight line/upright and "civilized" riding will wear the middle of the tire bald way before the edges are even touched. This in effect causes the rear tire to act as if it were a "flat profile" car tire and when actually in a sweeping turn or twisty the contact area is both smaller and the transition is more abrupt. (Right at a time when the exact opposite would seem to be needed..)
The ideal bike tire would be solid but with the right amount of compressability and resistance to deformation when exposed to side loading/transverse pressure. But then a solid tire would add a ridiculous amount of weight to the unsprung weight and inertia to the wheels themselves. So we have the shortcut of using tires as "balloons" to deal with the problem of weight/inertia.
The pressure in the tires should ideally keep the tires in the perfect shape in all riding situations: straight and twisty. Reducing the Psi for a more comfortable "softer" ride results in the tendency for the tire to deform earlier/easier when subjected to the side loading of the twisties or a nice sweeper turn. In this "turning" the degree of transverse loading is dependent on the overall weight of the bike and the rider/passenger along with the speed/delta of the turn itself. The sharper the turn/higher the speed the more the tire is subjected to the forces which try to deform it. I would suspect that the G-forces of some of the turns I have been in have resulted in the apparent weight of the bike being far greater than the weight of the bike just sitting in the parking lot. The only thing keeping it from deforming and taking less than an optimum profile/shape is the pressure inside.
I err on the side of putting the max pressure in both tires because I expect them them both to remain in the proper shape no matter what I encounter or have the courage to try/not try. What happens next is just friction co-efficient of the rubber compound/road and the laws of physics.
Haven't adjusted the pressures and done aggressive road tests or measured track times. I also make a dedicated effort to work the bike in order to keep the Kendos from looking like I left my sidecar at home. (No offense intended to any/all sidecar owners.)Comment
81 SH Something Special
79 SF MEAUQABEAUXS
81SH Nor'eas tah (Old Red)
80 LG Black Magic
78 E Standard Practice
James 3:17
“Alis Volat Propriis”
Yamaha XS 1100 Classic
For those on FBComment
Yeah... but nothing worse than a big white-wall on a tire.... except one they don't even bother to wash the blue off of.
 If I spent nearly $200 on a rear tire, you'd have to put sunglasses on to look at it.
Well, to each their own.
I forgot to bring it to 'Hena to get all you guys to sign it. Next time though.Ich habe dich nicht gefragt.Comment
Harry
'79 Standard
'82 XJ1100
'84 FJ1100
At least you know you have a spare tire at the house.
79 SF MEAUQABEAUXS
80 LG Black Magic
James 3:17
I run my forks at 14 lbs, rear shocks on 4 and 2nd from max spring
Me 33 Metzler front with 34 lbs
K491 Dunlop rear with 36 lbs.
This is my old setup on the '79. I still haven't figured out what I will use when I replace the garbage that is on my '80"There is a principle which is a bar against all information, which is proof against all arguments and which can not fail to keep a man in everlasting ignorance-that principle is contempt prior to investigation." --HERBERT SPENCER
Active: 1932 Ford Model A; XS1100SF (Just got 'er); XS1100SG; 2000 F250 Turbo Diesel; 2003 Ford Mustang
Broken: 1999 Kawi Vulcan 750; 1998 Triumph Trophy 1200
Gonners: XS1100SF (my first ride); '82 Honda CB900F (bored to 1123cc); '86 Kawasaki ZG1000Comment
