I do
The Great Ethanol Scam
Not only is ethanol proving to be a dud as a fuel substitute but there is increasing evidence that it is destroying engines in large numbers
By Ed Wallace
Here is a test or you can just use a glass jar.
The FAA cites numerous reasons alcohol and airplanes do not mix. Alcohol:
* Adversely affects the volatility of auto gasoline, which could cause vapor lock.
* Is corrosive and not compatible with rubber seals and other materials used in aircraft, which could lead to fuel system deterioration and malfunction.
* Is subject to phase separation, which happens when the fuel cools as an aircraft climbs to higher altitudes. When the alcohol separates from the gasoline, it may carry water that has been held in solution and that cannot be handled by the sediment bowl.
* Reduces the energy content of fuel. Methanol has approximately 55 percent of the energy content of gasoline, ethanol 73 percent. More alcohol equals reduced range.
From EAA website
From EAA website
By Ed Wallace
