hi all , dont worry this weather will soon break, ? anybody tell me the right position to have the pet cocks when on a normal ride with full tank of gas? , my 81 spec sh has off--pri--on--res, why?, where sould it be? thanks , mike.
off - shuts the fuel off
pri - prime the float bowls after removing the carbs or running out of gas.
on - normal run position
res - reserve fuel for just before you run out of gas.
This is your lucky time, go to the links section, look for MANUAL for 81SH message, click on link, and you can then download the owner's manual in PDF format for your bike!!!! Will possibly answer many questions for you!
79SF "The Teacher" . . .basket case! History shows again and again,
