Relocated
  • darrelldaltonga
    • May 2009
    • 25
    • St. Augustine, FL
    Relocated
    Hey guys just moved from Dalton, GA to St. Augustine, FL.....Wasn't able to bring my bike down on this trip but maybe when I do if i don't have the carbs adjusted yet maybe there's someone on here a little closer now that can help me out. Looking for work also...Have Class-A CDL if any one has some pull around here I'd appreciate the help with that as well.
  • tw1980
    • Apr 2009
    • 662
    • Bend OR
    Sorry Darrell can't help you with a Job on that side of the country.But I think you're in a good spot as far as opportunity goes.Be persistent and if you know someone is hiring don't take NO,get lost,or even hell no,for an answer.Make them give you a chance and then the rest is up to you.Good luck!! Terry
    1980 special (Phyllis)
    • darrelldaltonga
      • May 2009
      • 25
      • St. Augustine, FL
      hey thats ok i just appreciate the response. i got a couple of maybe's on the jobs but nobike buddies in this area yet
      • Cobia
        • Jul 2007
        • 1587
        • Palm Beach County, Fl
        Welcome to FL
        Hey Darrell,
        I believe there's an xsessive in Jacksonville. Look around on the site. He hasn't posted on the frapper map.
        1980G Standard, Restored
        Kerker 4 - 1
        850 Rear End Mod
        Automatic CCT
        1980GH Special, Restored
        '82 XJ1100 (Sold)
