Hey Folks,
Okay, I'm going to be helping a coworker replace his timing belt on his '04 Subaru BAJA with a flat four, DOHC. WE have a manual, but we know how they are not the greatest written material at times!
The instructions say to use a Chain Wrench with a piece of old belt to grasp the crank pully to secure it to then use a breaker bar to get the 22mm main pulley bolt loose. IT also says NOT to use an impact wrench or damage may result to the pulley or bolt??? WTF ???
I'm heading to Harbor Freight NOW to get one for tomorrow morning's mechanic work, but can any AUTO mech tell me why the manual would say that? I can possibly understand for tightening it, but for loosening it??
Also, will it be a regular thread...righty tighty lefty loosey?? The diagrams do not show the direction of rotation, I'm wanting to assume that it's clockwise as looking directly at the engine from the front? I know I can just bump the starter to check...doh! But hopefully they wouldn't use a reverse thread on this thing to prevent it working loose against the spin of the engine/crank??
Thanks in advance, will check back in about an hour...I need the chain wrench for other projects anyways!!
- NOW IT'S FOR SALE! $1,800 OBO
I (Swmbo's car actually) had a wonderful Ford Escort with a straight 4, luckily after they redesigned the valve clearances so that WHEN(not if) the timing belt broke, it didn't eat valves! It was to be checked at 30K and replaced at 60K, but I had to replace it every 30k. It died first in her work hospital parking lot and I did the repair right there. I drilled a hole thru the right wheel well to access the tranverse mounted engine/crank pulley bolt. Used an old trick of wedging the wrench against the wheel well/frame and tapped the engine over to break it loose, and YES it was a REVERSE threaded bolt! Had to do this 2 other times, got it down to about 2 hours! We ended up putting over 90K on that machine, never had to tear the head off, it never bent valves even though the belt would break several teeth right at the crank, crank would spin, cams would not!
The crankshaft pulley bolt is only 130 ft/lbs....yes, not NEWTON/Meters!
Should be fun!
