The Dog House
  • The Dog House
    well i just picked up the oil the filter will be coming in to morrow and the carbs should be done here soon so i think that this xs11 will be done here soon and now i think i have a name for it cause every time i go get anything for it and or talk about it i i get in the dog house so the name of this bike is THE DOG HOUSE but i will let you all know here how every thing is going on this post so i don't keep on asking question on some one other post
    1980 xs 11 special
    The motor vehicle action sequences depicted in this film are dangerous. All stunts were performed in controlled environments with professionally trained stunt crews on closed roads. No attempts should be made to duplicate any action,driving or car play scenes herein portrayed.
    well started to get in to the bike a little and now starting to find out why it was free. the guy that owned it be for me must of started to take parts off of it there were things in the parts bin that after finding where they went took me 4 hr to get them all in and all the bolts that were loose it is getting there. so i just picked up oil and a new filter for it and all that will be going in here to night will be getting carbs back on sunday so i will let you all know how it runs then and then i am going to pick up a vac gauge to set the sync them
    1980 xs 11 special
      Don't forget to take pictures! Before and after threads are great! Gives you a great sense of accomplishment when you see what you've done, all by yourself.
        well i just look at my carb's apart and he ran in to some problems with well it looks like i will need i float needle it was so stuck that he broke the needle coming out at least he did save the bushing that it sits in but now i need to try to find a float needle if any one has a spear or know where i can get one in minnesota it will be help full
        1980 xs 11 special
          Highly recommend you replace the float needles and seats. Especially if they are that dirty!
          I believe Mikes XS sells them.
            Chevy ,will you put what year and model of bike you have in your signature?
            It will make it much easier for folks to be of service to you.
            If you have the late model carbs(80 or 81) then you probably have viton tipped needles.If you have early model carbs(78 or 79)you probably have all
            metal needles.Anyway like DGXSER said you will be much better off replacing all
            four needles.Especially if they are viton and they are as nasty as they sound.And it is cheaper to buy kits than to buy just needles from what I have seen.ANd kits will have the needle and seat and gaskets and o-rings for .Some even have new jets.
            80 SG XS1100
            14 Victory Cross Country
              well it is running but i still need to fix some little thing right now if i have the the of off switch on the tank i put it on on it idles at 800 1000 rpm if i put it on res i idles at 1000 2000 and if i put it on prim it idles 2000 3000 rpm any help will be good or do i just have the fuel lines on wrong
              1980 xs 11 special
                Sounds like the carbs still aren't totally clean. Not sure what you mean with the variable RPMs though. Does it jump around while idling? If you go back and forth between the petcock settings, do the RPMs go back to the same level again? Usually, the RPMs stay perfectly still unless you pull on the throttle.
                  unless the diaphragm in the petcock is going bad. in which case the low idle on "on" would be because there is not enough vacuum to pull it open and the high idle on prime would because it is not facing any resistance.
                  Whoever coined the phrase livin' the dream forgot to mention whether it was a good dream or bad dream.
                  '79 XS1100F "Lucy"
                  75,000 miles and still goin strong.
                    it stays right in that range but i was just out there again and the vac line was not hooked up no it is running just fine on the on position so i fixed that now what it is doing is it idles at about 1000 rpm steady but it has this funny pop and when i turn off the tights to see if there is flame anywhere when it does that little pop there is flame in the vac line going to the diaphragm so then i turned if off and came in here and typed to see what you all think
                    1980 xs 11 special
