This site will be temporarily offline this Friday April 18th from approximately 5pm PST (UTC-7), for a few hours or less (hopefully) for upgrades. See this post in Forum Announcements for more info.
I can say that the part # you have IS for the REAR caliper, both 650 and XS11, standard or special, because they used the same caliper for that application.
However, I can NOT say it'll work for the front. Yamaha gave their rebuild kit a different prefix, 2G2 instead of 1J3, and they do that WHEN it's not the same exact part, size, etc.! Both have the same suffix, W0037.
The Special's front calipers are different, different sized/depth piston, don't know if they are the same diameter,
but I can't say for certain that the kit for the rear will work for the front??
Partsnmore has a dual caliper front Special rebuild kit listed, #29-0034 IIRC!?
79SF "The Teacher" . . .basket case! History shows again and again,
Thanks TC,
That is information I better log down somewhere. It'll probably come back around.
I think I'll start a book on crossover numbers and their sources, for XS1100 Bike parts.
Are there so many more XS650's around because production was so much higher?
I have no idea how many were built but it seems odd that I think I have seen maybe one 650 in I can't count how many years but I still see the occasional 1100.
Oh well, better start that book....
Thanks again TC,
Rodger
Wow, I really didn't know they were around that long. Must not be anywhere near 14 years worth of roadworthy 650's out there.
I suspect the reason I don't see many of them is because there isn't much of a XS650.com website out there. - - - Rodger
Hi Rodger,
most likely you can't find our excellent, erudite and prolific site is because it ain't a Yahoo thingie but is accessed via Micapeak.
Go here:- http://micapeak.com/mailman/listinfo/yam650
