Oil and concrete (spill)
  • Thee_oddball
    • Apr 2009
    • 87
    I made a mess when i tried to change the oil on my bike (another post and story) I was wondering if anyone could suggest a solvent to break down the oil so i can power wash it off...i already used a power washer today but it only removed about %20
    thnx for any help
    1982 XJ1100J MAX ,25.000 miles
  • GARTHXS
    • Nov 2007
    • 1631
    • Seattle
    detergent
    try some powdered tide , a little water scrub and let it sit for a couple of hours wet than scrub and rinse.
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
      • 8797
      I use Pour 'N Restore. This stuff works great, it sucks the oil right out of concrete. About $9 at Ace Hardware.
      Pour-N-Restore oil stain removers and waterless hand cleaner have been crafted using the highest quality ingredients to remove oil stains, grease and other grime. Award winning performance is here.
        Hi oddball,
        Just because I never heard of pour'n'restore don't mean it don't work but TSP (Tri-Sodium Phosphate) works too. Sprinkle the crystals on the oil stain, wet down a coarse broom and scrub to make a slurry. Then blast clean with the pressure washer.
        • CatatonicBug
          • 6117
          • Clinton, UT
          I just keep a bag of oil dry (the cheap kitty-litter stuff) in the area were I'm working. In fact there is a pile under my bike most of the time. If I make a spill, I scoop up a handful and pour it over the spill. I let it soak a bit, then do a little dance on the pile to rub it into the oil. After a day or two of sitting, I just sweep it out of the way, and re-use it for the next spill. It doesn't necessarily clean up the "stain" but it picks up the oil and allows me to keep working.
          • D. P. Larmee
            • May 2003
            • 224
            • Evanston, IL
            I second the kitty litter. Don't use the clumping kind; the good old regular stuff is the best. I always have a big bag in the garage for just this sort of thing.
            1980 XS 1100 Standard
            1980 XS 1100 Special
            1982 XJ 1100
            1972 Honda CB 350
            • petejw
              • 2269
              • sydney australia
              i'm a kitty litter fan as well and i dont have a cat. :-)
              its cheap ands absorbs the oil well.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • Bowtied
                • Jul 2008
                • 150
                • oklahoma city ok!
                Drive up cleaner. Available at autozone (and other auto parts stores i'm sure. I work at autozone so i know it's there). Pour it on the stain and let it sit (preferably over night but not necesary) then just power was it away. Bout 7 8 bucks and your done. Cheap and easy.
                Yes it's a damn nice bike, yes it's in REALLY good condition, yes it would be a shame to chop it, BUT damn how cool would it look with ape hangers?
                • tw1980
                  • Apr 2009
                  • 662
                  • Bend OR
                  "Oil Eater"in the automotive section at Costco.It also does a great job on tires and raised white letters or white walls. Terry
                  1980 special (Phyllis)
                  1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner mod
                  • HobbyMan
                    MeatHead Idiot "GURU"
                    • Jul 2006
                    • 1801
                    • Colleyville, TX
                    My $.02
                    Throw some soap and kitty litter on it. Not much you can do. At home, I just always work in the same spot (usually), so that it gets stained and I don't have to worry about it. When I was on my ship working on steel decks, the best thing you could do was lay cardboard down before you do a job involving fuel or lube oil. If not, you will track it everywhere. Oily decks are very dangerous, especially when the ship is pitching and rolling. The fuel we burn out at sea looks like used motor oil (only much more viscous) with dirt mixed in so you can imagine how much of a mess it makes.
                    Acta Non Verba
                    • Ivan
                      • Jul 2008
                      • 2524
                      • Hutchinson KS
                      Best way to clean an oil stain is use MEK, douse it down really well and then absorb it with floor dry (most of the time cheaper than kitty litter, but the same stuff). In the absence of MEK carb cleaner will dilute it enough that the floor dry will get it up.
                      Ich habe dich nicht gefragt.
                      • Thee_oddball
                        • Apr 2009
                        • 87
                        Gentleman thank you very much for your responses, i feel alot better knowing there is a way to clean up the mess (will make my landlord happy too )
                        thnx again
                        • HobbyMan
                          • Jul 2006
                          • 1801
                          • Colleyville, TX
                          One more suggestion for future use.
                          A big sacrificial carpet. I have some old carpet that got ripped out of a house that I threw in the garage. I will soak up a little drips here and there and it makes working on your bike much more comfortable when you have to kneel or lay down on the ground.
                          Acta Non Verba
                          • Thee_oddball
                            • Apr 2009
                            • 87
                            thnx hobby, i had cardboard and 2 large cans ready for the oil..what i was not ready for was the half gallon plus of gas that had leaking into the oil from the carbs shot out like a fire hose and over loaded my cans before i could do anything ...ive decided that to avoid this problem im going to put 80W axle grease instead of oil in the bike so it wont shoot out next time
                              • 7765
                              To keep the landlord happy, try and find a little bag of dry cement. Sprinkle that on the spill, let sit for a day or two, and sweep what's left off. It will "take away" the oil stain.
