I recently bought a set of frogg toggs, not the road toads, cause I couldn't see spending the extra $35 for some reflective tape, but I have a set none the less. I have a buddy that has a set of gauntlets I can use and I have put a generous slathering of mink oil on all my leather stuff. Thinking of getting some rainx for my helmet screen.
Is there anything else I should look out for when riding in the rain? Something an inexperienced guy wouldnt think of.
). Make sure your footgear is water tight also. They make some booties that will slide over your shoes and keep your feet dry. Make sure the collar will go up UNDER your helmet and stay there when you are riding. Ditto with the sleeves, need to go UNDER the gloves if at all possible. Take a roll of duct tape with you, it may not be styleish but it can seal things up and keep you dryer. Watch out for the cars/trucks in front of you and coming up behind you, the spray can equal a whiteout. Watch the cars/trucks in front of you, if you see them hit a big puddle and pull to one side, do what you can do to keep from hitting that puddle, a hydroplaneing motorcycle is a new adventure in fear. Other than that, have fun and do watch out for the grease slicks. 'Course having a full fairing or windsheild can make rain riding a little better. Oh yeah, fill your plug caps with die-electric grease, water and spark is not a good mix.
You might not even need to bathe if you get wet enough.... but only if you aren't in the same room with me. Wet gorilla hair has got to reek... BUT.. you and Bigfoot could maybe get in some quality time grooming each other?? (Again.. not in the same room as me please.. )
but keeps my feet dry.
