81 SH SomethingSpecial 81 frame, 80 tank and side covers, 79 tail light and carbs, 78 engine, 750 final drive mod, Geezer rec/reg, 140 mains, LH wheels
79 SF MEAUQABEAUXS 81SHNor'eastah (Old Red) 80 LGBlack Magic 78 EStandard Practice
James 3:17
Yup!! Those side covers and valve cover look SWEET!!!
That sounds fantastic I was talking about using a 'Cherrie Bomb" a few weeks ago when I was at SlowMo's ,place thanks for posting the video. I like the way it sounds much better than my Mac mufflers.
BDF Special
well, if you do, check into which size you will need. I got the one with the 2 1/4" inlets, and it was the same size as the header. I had midas expand the header to make it fit, but if I did it again, I would find one that fit better.
I had to weld a bracket on the side of the cannister to make it work well. I repainted it with VHT header paint. I may end up putting some engine clear on it to get a shinny look instead of the flat. I think a nice chrome tip on it would look great, but everything readily available to me on Sunday afternoon is the exhact same size as the outlet. I am guessing Midas will have something that will slip over it without having to resort to more expanding.
I think you will be pleasantly surprised at the sound.
