how do you keep excel columns expanded?
+ More Options
Posts
  • mason79
    • Mar 2006
    • 1351
    • los angeles, ca
    i get these spread sheets, they are crammed with data and many columns,
    i drag them open it takes me forever.
    when i close the file and open them up later all the columns are back to their skinny little selves, and i have to redrag them.
    this needless to says is very frustrating,
    is there a way to save this stuff the way i want it?
    help and thanks
    xs1100 forever!!!
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
  • randy
    • Dec 2003
    • 4521
    The sheet may be protected. In the TOOLS tab, unprotect the cells. Before you do your 'dragging open', try clicking on the little square box at the upper left of the cell header, that will highlight the entire sheet then you can drag all of the columns open in one action. drag open one and the rest will follow.
    • egleaves
      • May 2007
      • 441
      • Sacramento
      As Randy said, you need to make sure the sheet protection is turned off first.
      A method I like for resizing column widths is to right click (i think) on the column header and there is a selection for adjusting the column width. If you click this you will get a small text box where you manually enter the width you want. Now here's the fun part; if you click on the next column you want to re size (just a left click to highlight the cells) and then press "ctrl+y" that column will then be set to the same width you entered into the last one. Ctrl+y will always repeat the last command or formatting you applied to a cell or group of cells. I use this a lot for repetitive spreadsheet tasks.
      I know this, because Tyler knows this.
      1980 SG
      3J6 003509
      Kerker 4-1 (sans baffles)
      Fuse Block Upgrade
      Mike's XS Green Coils
      Pods w/Homemade Velocity Stacks
      • ELDR
        • Aug 2007
        • 212
        • Ottawa, On, Canada
        You can also left click on the top header of the first column and the drag across to the remaining columns to select all you want. release the left click and then right click, select column width and enter a new width for all columns.
        • Jerry
          XS & TRUE XJ GURU
          • 3023
          • Elma, IA.
          Make sure you do a Save after expanding the columns, even if you have not changed any data.
          Jerry Fields
          '82 XJ 'Sojourn'
          '06 Concours
          My Galleries Page.
          My Blog Page.
            My favorite method for expanding columns is to highlight all of the columns like ELDR said, then hover your cursor on the line between any two of the column headers (between the letters D & E for example) until the cursor looks like a bar with an arrow pointing in each direction. Then, double-click there. That will auto-fit all the columns to the size of the largest item in each column.
            Saving is also required to keep the changes made. And remember that if you are getting these spreadsheets via e-mail, you need to save them outside your e-mail (like to your "My Documents") to save changes.
            • mason79
              • Mar 2006
              • 1351
              • los angeles, ca
              thanks gents any method was better than mine and i suffered for years, idiot, you see perfect example of a not asked question being stupid.
              randy's solution was the best, 1 or 2 step process, won't save, but it's close enough, thanks!
              History
              85 Yamaha FJ 1100
              79 yamaha xs1100f
              03 honda cbr 600 f4
              91 yamaha fzr 600
              84 yamaha fj 1100
              82 yamaha seca 750
              87 yamaha fazer
              86 yamaha maxim x
              82 yamaha vision
              78 yamaha rd 400
