hello from Brisvagis - one bikes story
  • aussixs11G
    • 76
    • Brisbane Australia
    I bought the XS11 from a mate – he was down on his luck and only parted with it as a matter of need for cash. My former wife didn’t approve of bikes so I had had some 15 years in a bike free wilderness.
    Leesa, on the other hand, is supportive and everything a wife/partner/friend could ever be.
    Anyhow, the bike, a helmet and jacket became mine for $1200 back in 1995.
    The XS had been crashed, had a bogged dent in the tank, sported the crappiest 4 into 1 “Transac” system, but was otherwise OK, basically stock standard with about 120k klms on the ODO, been around at least once. (if you can believe an ODO)
    I used the machine on a daily basis and enjoyed many weekends away with Leesa as a willing and competent pillion passenger.
    In around ‘98/99 I met friends who were involved with Club Laverda Qld (www.clublaverdaqld.org) and became a member. I had never belonged to an enthusiasts club before and found that I fitted right in. I bore the brunt of many “jappa” and “ujm” jokes but these were in good humor and anyway I was not the only member who didn’t ride a Laverda.
    I did the “Bikes are Back” Bathurst run in 2000 with Club Laverda mates – awesome weekend – 3 days of bike racing at Mount Panorama. I traveled heavy – took way too much gear – learned a lot that trip.
    By now the XS had developed a nasty oil leak from the base gasket and it was time to overhaul. I have read of the “church of unnecessary modifications” and find that I am of the faithful.
    As well as boring to 1130 (Wiseco kit), lightening and polishing the crank, balancing all reciprocating parts, modding the gearbox, new bearings/shims in the middle gear case and dif, new everything (primary chain, bearings, etc), porting and gas flowing the head, Ivan Tighe camshaft (253B grind), I consulted with Mal Pitman regarding making the machine handle less like a cruiser and more like a sport bike.
    Mal’s suggestions included that I should strip some unnecessary weight from the whale (lost the mammoth indicators, horns, centre stand, unused lugs on the frame, you get the idea), have the frame straightened (put the wheels in the same plane), stiffen the swing arm, make the engine part of the frame (lose the rubber engine mounts), and alter the steering geometry.
    I am fortunate in having as a friend “Wobbly Bob” Castle. Bob is a motorcycle drag racer (Suzuki GS1000 and Katana) of renown from here in Brisvagis who has an exemplary workshop and competent associates in the field of m’cycle modifying.
    It was using his contacts that the headwork, engine boring/balancing, and gearbox mods, and final engine assembly were completed.
    Dave Kellett Motorcycle Engineering at Slacks Creek is the man to repair/straighten frames here in Queensland. Dave raced sidecars here and in Europe and is a contempory of Mal Pitman. Dave straightened my frame and tweaked the steering head angle.
    I made the drawings below for a friend to fabricate the swing arm brace.
    The frame/swing arm I had sand blasted and powder coated – next time I will paint – the powder coating is prone to becoming discolored and cannot be repaired when needed.
    I had a local engineering shop fabricate billet aluminum engine mounts to my drawings and these were siliconed into place on assembly (eliminating vibration). I had high tensile engine mount bolt made up (the long one) with a finer thread as this was a bit corroded.
    The machine was painted Ford XR6 blue (blueprint) at the first re-build – I liked the color – simple.
    The front forks were modded and fitted with a fork emulator kit (FEGV S3301) and constant rate springs from www.racetech.com - using the best quality auto gearbox oil (Dextron 3) as fork oil (volume as per manual (212ml i think)
    The emulators are great once you have adjusted them correctly for your style of riding and prevent that sickening bottoming out of the suspension in potholes or the like (we don’t have roads here in Queensland just road works) - the performance is v similar to a modern (cartridge) front end.
    At the back I'm using units from www.bitubo.com (model WME02) - these have "micrometric spring preload adjustment" and rebound adjustment - I should have spent the extra and bought the model with compression adjustment but there it is.
    The object of all this was to make the machine handle in the twisties - its no fun fanging with your mates if they leave you behind....................
    The “divers mask” headlight I never liked so the round unit has taken its place. I had the rear guard shortened and this has really made the machine look more modern (as well as simplifying rear wheel removal)
    I fitted Laverda Jota ‘bars at this time but they were always a little awkward with the stock foot pegs. I tried MX bars (Renthal) – these were great around town but turned one into a windsock on a run.
    With the machine in this configuration I clocked up around 20k klms including some commuting, a trip to Phillip Island for the MotoGP, and numerous “high mileage runs” with mates (1500klms in a weekend)
    In May ‘07 I allowed No 2 son to borrow the XS for a fang with his mates (sons 2 and 3 are both competent riders at that time owning R6 and VTR1000) and he crashed heavily – he road the machine home to his credit (bent frame, ‘bars, crushed/leaking tank, smashed gauges, 1 less foot peg, no clutch lever, bent seat base) he low sided then the bike slid/tumbled down the bitumen scraping basically everything. Moral is … NEVER LOAN YOUR BIKE.
    The XS languished in the shed until last Sept when, after a strip down, a massive hunt for gauges, much polishing, and a serious frame straightening, she was reborn in orange – I sourced rear sets and here we are……..
    The bar end mirrors are from www.austreetfighter.com.au http://ausfr.com.au/cart/shopdisplay...arch=yes&bc=no
    I heard they are not street legal here but I haven't been pulled up yet and they work great. The gauges are stock, switch blocks are XJ1200 (needed some re-wiring to plug into XS), the grey gauge on the LHS of the 'bars is a bicycle speedo ($69, v accurate, gives speed, odo/trip, max/av speed, elapsed time, and has a clock. More expensive units are wireless and have a backlight function) the sender is on the LH front brake rotor. The Laverda Jota 'bars combined with the rearsets suit my style of riding. The brace on the swingarm is visible here.
    The 'bars are not quite stock Laverda Jota 'bars - I had to mod them after the last crash by straightening and lengthening the end parts (needed more bar length on the throttle side than a Laverda) I used heavier gauge pipe - this turned out to be a *uck up as i've had to machine the weights for the bar end mirrors to fit into the ends. I also had an issue with vibration in the RH bar – mostly fixed now by driving a few 75gm lead sinkers down the bar end.
    The rear sets are "off the shelf" http://www.raask.se/fy40.jpg
    My late father was a pattern maker and I have certain expectations regarding the finish of castings and so was sadly disappointed - once I had linished the cast brackets (removing the makers marks in the process) they bolted on, adjusted up and work all without a problem
    You will find the Jota bars on the Raask site also but I don't know about quality.
    With the help of B1, a CLQ clubbie, the seat base has finally been repaired and the seat re-covered (an expert job done by John Moorhouse at Evo Seats here in Brisvagis – turns out his late brother raced XS11’s in superbike back in the day here in Australia)
    So the bike is again entire – now about that electronic ignition timing and dialing the camshaft timing……….
    Bryan H
    "Conan, what's best in life?"
    "To crush your enemies, drive them before you and the lamentation of their women"
  • planedick
    • Mar 2005
    • 2068
    • Yorba Linda, California
    Very nice
    Lots more history and pictures than we usually get from newbies for sure. VERY NICE bike for sure and you have done a great job of restoration two times. The XS11 will live forever if properly maintained.....
    Drilled airbox
    Tkat fork brace
    Hardly mufflers
    late model carbs
    Newer style fuses
    Oil pressure guage
    Custom security system
    Stainless braid brake lines
    • blue giant
      • Aug 2007
      • 880
      • Ontario, Canada
      Awesome story!
      Thanks for sharing!
      Paul
      Paul
      1983 XJ1100 Maxim
      1979 XS1100 Standard
      1980 XS1100 Special
        VERY cool bike (although I think I liked the blue better) and obviously a labor of love. That's a definite keeper.
        How did the solid motor mounts work out? More buzz in the bars? Better handling?
        ....and there's no such thing as a 'unnecessary mod' if YOU like it.... LOL
        '78E original owner
        • aussixs11G
          • 76
          hey steve
          there is a buzz in the bars at about 3500rpm so around town
          its a nuisance - handling ? the limitation appears to be the size of my cahonies................
          Bryan H
          • Guest
            nice
            very nice ride!!!!!!!!!!!!!!! kind of scary gas price at your gas station
            • 79XS11F
              • 3563
              • Ottawa, Ont. Canada
              That swing arm addition is a neat idea .. I like that ...
              Nice Ride ...
              Rob
              KEEP THE RUBBER SIDE DOWN
              1978 XS1100E Modified
              1978 XS500E
              1979 XS1100F Restored
              1981 Suzuki GS1100
              1983 Suzuki GS750S Katana
              1983 Honda CB900 Custom
              • ELDR
                • Aug 2007
                • 212
                • Ottawa, On, Canada
                Hey
                In your photos of the left side, orange1100251008008.jpg and orange1100251008009.jpg, I noticed an extra shaft protruding from the crank case cover forward of the shifter. My G doesn't have one. I see from the parts manual that covers in 81 and 82 have a boss for the shaft but not a shaft. What's that shaft do?
                • Wildkat
                  XS Special Gurette
                  • Apr 2004
                  • 3416
                  • Location, Location
                  Great write-up!
                  and sweeeet bike...
                  I LIKE the orange (and I don't usually like orange)
                  81 SH Something Special
                  79 SF MEAUQABEAUXS
                  81SH Nor'eas tah (Old Red)
                  80 LG Black Magic
                  78 E Standard Practice
                  James 3:17
                  “Alis Volat Propriis”
                  Yamaha XS 1100 Classic
                  For those on FB
                  • aussixs11G
                    • 76
                    eldr
                    that is the pivot for the stock gear shift linkage- the rear sets dont use it - you guys really look close don't you.......
                    Bryan H
                    • 81xsproject
                      • 3185
                      • Fortuna, CA
                      No, we just see SO many pics of elevens that when we see one that has something that looks mechanically different, it stands out. Awesome post.
                      '81 XS1100 SH
                      Sep. 12th 2015
                      RIP
                      • aussixs11G
                        • 76
                        cam games
                        OK - yesterday pm spent 4 hours fitting new camshaft and slotted cam sprockets to my alledgedly sh!!T hot Ivan Tighe Engineering camshafts (253B grind), dialled in and now have a beefier mid range (4000-5000 rpm - a definate surge)
                        HOWEVER..... the cam lobes (in & ex) are worn and will be binned as soon as I can source a pair of stock camshafts. (only 25k klms use)
                        I have changed main jets from 132.5 to 140 as there was some leaning out happening (Bigger 4/2/1 exhaust and K&N filter)
                        more later
                        Bryan H
                        • b.walker5
                          • Feb 2009
                          • 1745
                          • Invercargill, New Zealand
                          Hi AussiXS11G.
                          Very cool bike, love the colour. You might not have a Laverda but you've sure as hell got a close second.
                          I usually make it to Aus a couple of times a year for holidays and business etc and would love to come and check it out and swap engine notes. I have a nephew in Brisbane so it could be a good excuse to visit him for a couple of weeks later this year. Jetstar are advertising $99 flights for travel in July.
                          Let me know if thats okay.
                          • Steptoe
                            • 175
                            • Thabeban,Bundaberg QLD , Australia
                            stock cams
                            hi aussie11.guess what? got stock cams in my shed, in & ex, go to members, look us up
                            never ride faster than your gaurdian angel
                            can fly
                            1981 rh 5N5
                            MIDNIGHTSPECIAL
                            1188cc
                            4 into 1 pipes with a transac muffler,
                            as the motorcycling gods intended everything else stock std
                            http://s856.photobucket.com/home/steptoexs11
                            http://steptoexs11.webs.com/
                            http://www.youtube.com/my_videos?feature=mhum
                            1982 vf750 sabre
                            • lakecountrydave
                              • Aug 2007
                              • 384
                              • Phoenix, AZ
                              Great story and loved the pics! She looks sharp in both of your builds
                              Dave
                              1979 XS1100SF Special
