Tools Explained
  • oseaghdha
    • 1075
    • N43.02.5,W88.14.2
    Tools Explained
    Some old, some new.
    DRILL PRESS:
    A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted vertical stabilizer which you had carefully set in the corner where nothing could get to it.
    WIRE WHEEL:
    Cleans paint off bolts and then throws them somewhere under the workbench, at the speed of light. Also, it removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, ‘Oh sh--....'
    SKILL SAW:
    A portable cutting tool used to help you make studs too short.
    PLIERS:
    It is used to round off bolt heads. Sometimes used in the creation of blood-blisters.
    BELT SANDER:
    An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
    HACKSAW:
    One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked and unpredictable motion. The more you attempt to influence its course, the more dismal your future becomes.
    VISE-GRIPS:
    Generally used after pliers to completely round off bolt heads. When nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
    WELDING GLOVES:
    Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
    OXYACETYLENE TORCH:
    Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub, out of which you want to remove a bearing race.
    TABLE SAW:
    A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
    HYDRAULIC FLOOR JACK:
    Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
    EIGHT-FOOT LONG YELLOW PINE 2X4:
    Used for levering an automobile upward off of a trapped hydraulic jack handle.
    E-Z OUT BOLT AND STUD EXTRACTOR:
    A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use. It is one of the best examples of false advertising in naming a product to entice buyers.
    BAND SAW:
    A large stationary power saw primarily used by most shops to cut good aluminum sheets into smaller pieces that more easily fit into the trash can after you cut on the wrong side of the line.
    TWO-TON ENGINE HOIST:
    A tool for testing the maximum tensile strength of everything you forgot to disconnect.
    CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER:
    A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
    PHILLIPS SCREWDRIVER:
    Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
    STRAIGHT SCREWDRIVER:
    A tool for opening paint cans. It is sometimes used to convert common slotted screws into non-removable screws.
    PRY BAR:
    A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
    HOSE CUTTER:
    A tool used to make hoses too short.
    HAMMER:
    Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
    MECHANIC'S KNIFE:
    Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. It is especially useful for slicing work clothes, but only while in use.
    DAMMIT TOOL:
    Any handy tool that you grab and throw across the garage while yelling 'DAMMIT' at the top of your lungs. It is also, most often, the next tool that you will need.
    XS1100SF
    XS1100F
  • GARTHXS
    • 1631
    • Seattle
    dont forget
    Duct tape, bailing wire and jb weld!
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
    • cruiser
      • Jul 2004
      • 393
      • Winona, Minnesota
      I like it Dan and worthy of pasting on my garage wall.
      Of course below it will be written in blood,
      BTDT
      XJ1100 Ruby Red
      XS1100LH "Midnight"
      1972 MGB Roadster "sold"
      • Wildkat
        XS Special Gurette
        • Apr 2004
        • 3416
        • Location, Location
        Whew!
        I am SO glad to know I've been using them all correctly after all of this time...
        Thanks for the affirmation, Dan!
        81 SH Something Special
        79 SF MEAUQABEAUXS
        81SH Nor'eas tah (Old Red)
        80 LG Black Magic
        78 E Standard Practice
        James 3:17
        “Alis Volat Propriis”
        Yamaha XS 1100 Classic
        For those on FB
        • ccogswel
          • Jun 2005
          • 302
          • Bowling Green, Ky
          Oh this was good. LMAO!
          Needed to add Band-aids, Fire Extinguisher, Drop Light.
          Chris
          79 XS1100 Standard aka: Mutt
          Gimme Fuel Gimme Fire!
          • nashville_bill
            • 605
            • Nashville, TN
            Great post; I just copied it and forwarded it to all my buddies.
            Bill Murrin
            Nashville, TN
            2005 DL1000 V-Strom "WOW"
            2005 FJR1300 Newest ride
