bringing my tools home. . . . maybe?
    Silica is a desacant and will obsorb moisture, but it only obsorbs so much. Luckily, it will also give it back up to dryer air. however, the air can't take it at cold temps, so they will only do so much.
    As was stated in another thread somewhere, the issue is not so much the moisture in the air but the fact it condenses out on the surfaces, like your engine, or tank, or your tools because the environment they are in is warmer, they hold that warm air inside the box, then the temp slowly drops inside the box due to heat transfer through the box, to the dropping air temps. But moisture does not transfer through, so you get high moisture and low temps which equal condensation. My tools live in my craftsman tool boxes in my unconditioned garage. They dont seal at all, so free air movement in and out. Been there for alot of years, not a one of them has rust on em. However, on a particularly warm winter day in December, I opened the garage door when it had been about 30degrees cooler in my garage than outside, water was running off the bike, and my tool boxes. No rust yet on them though. Just my two cents.
      The trick we always used when we had to store electrical equipment in damp areas was to 1. get it off the ground 2. Cover it with plastic to the ground 3. put a light bulb under it.
      The heat given off by the bulb would keep the dew out, and the plastic would keep the heat where you want it. You don't need a large bulb; for a rollaway chest I'd use a 50 or 75 watt, smaller for a tool box. Dessicants work too, but only for a while.
      78E original owner
      • BigDick
        • 521
        • McConnell AFB, KS
        something else i just thought of (thanks tc for mentioning dessicants) is they sell cans of dehumidifiers to use in gun safes, and they are "rechargeable" ie. you bake the can in the oven at ~250 degrees for x number of hours/minutes then put it back in the toolbox/gun safe etc.
        1980 XS11SG
        Dunlop elite 3's, progressive fork springs, tkat brace
        Stock motor, airbox, carbs, exhaust
        ratted out, mean, and nasty
        • Toolmaker Tim
          • 671
          • South Bend, Indiana
          I put Champhor blocks in my toolboxes at work. You can get them at the local drugstore, but you might have to have them ordered. Hope it keeps them from rusting while I am unemployed.
          1979XS1100SF
          K&N's and drilled airbox
          Jardine 4in1
          Dunlop Elite 3's
          JBM slide diaphragms
          142.5 main jets
          45 pilot jets
          T.C.'s fusebox & SOFA
          750/850 FD mod.
          XV 920 Needle Mod.
          Venture Cam Chain Tensioner
          • Toolmaker Tim
            • 671
            Also keeps the spiders and other creepy crawlies out of your tools!!!
            1979XS1100SF
            Jardine 4in1
            Dunlop Elite 3's
            142.5 main jets
            45 pilot jets
            750/850 FD mod.
            XV 920 Needle Mod.
