Folks had done numerous things, but basically it comes down to getting them out. Drill a hole in them (being VERY careful not to punch through and screw up the idle screws) and then stick something in the hole and pry them out. Somebody said the drilled and then screwed a wood screw or something in the hole. Then they used the screw to pry them out.
The 80-81 carbs came with plugs that suppose to prevent the owner from changing the settings of those screws that were factory set in accordance with EPA dictates in the USA. As 81xsproject said in his post, drill a small hole in those caps 1/16 in. and screw a self tapping sheet metal screw in to them, being sure not to go too deep as to mar the tops of the air screws. Grab the sheet metal screw with a vise grip and fulcrum the caps out. You can leave these caps off after adjustment as they serve no purpose other than to stymie the owner from adjusting these factory set screws. When buying new air screw assemblies for the 80/81, you will get those plugs in the kit. They are not needed.
I was lucky with mine, as the caps had already been removed. However, I was rather confused by the rebuild kit I got, because it included new caps! I had no idea where to put the things. Seems like a silly idea to me... Does anyone actually put the caps back in?
I posted that I thought that putting those caps back in would prevent dirt and grit from accumulating in the towers but was disuaded from doing so by TopCat. His reasoning was that you need to adjust those screws from time to time as you re-synch the carbs. Good enough for me as I have had to tweek those screws over the last year after re-build of the carbs.
