Uh oh, not again...
  • Crazcnuk
    • 2980
    • Hinton, AB, Canada
    Uh oh, not again...
    Well, I haven't pushed the '80G into the river, yet, and I can't afford to get it excorcised...
    So, like an idiot, I picked up an '80SG the other day!
    $300CDN for a running, 99% complete '80 Special, couldn't pass it up.
    It's going to need the usual clean and polish, some tank emblems, brake cleaning, right side front footpeg, battery and a seat recover.
    The PO buggered up one of the idle mixture screws and tried to cut down the 'well' to get at it, but the carb is still functional.
    The bike has 68,000kms on it.
    It has a carrier with backrest, 4 into 2 turn-out exhaust and a windscreen.
    '05 ST1300
  • Bigfoot
    XS-XJ GURU
    • Sep 2005
    • 1422
    • Kansas City, Missouri
    Congrats on the new bike. I hope it works out for you.
    Harry
    '79 Standard
    '82 XJ1100
    '84 FJ1100
    Acta Non Verba
    • oseaghdha
      • 1075
      • N43.02.5,W88.14.2
      A triumph of hope!
      Good luck, maybe this one is not snake bit.
      XS1100SF
      XS1100F
      • tarzan
        • 1700
        • Chandler,Az.
        Nice buy Crazcnuk,
        Now its time to start a new fix craz bike thraed.hehe
        80 SG XS1100
        14 Victory Cross Country
        • thewiz
          • Oct 2006
          • 1115
          • Wilksboro, NC
          And so it begins again ....
          Some of us are just XSessive beyond all understanding ... I, for one, admire your courage and fortitude. I'm right there with ya' .... Garth is too .... lol. May this one be the good one ....
          80G Mini-bagger
          Past XS11s
            Craz...I just finished dealing with a badly stuck mixture screw myself. Even broke an extractor off in it. Wound up getting a local machine shop to use an end mill to just under the minor of the threads, then pulled the choke out and used blaster and heat back and forth and got the rest of it to peel out.
            Best of luck with it!!
            • latexeses
              • Jun 2008
              • 1491
              • California
              DGXSER...
              Don't scare him off!
              Everything on hold...
              • Crazcnuk
                • 2980
                No worries there, I had to drill one out on the other XS. I drilled it out as large as I could, then used a reverse drill bit to get the rest out.
                I am hoping this one isn't possessed like the other one.
                At the very least it will give me one to ride around while I fix the std. I have a cylinder head and valves on the way for that one too.
                If I get both working I will have one of each, the special for just buzzing around and the Venture for long trips.
                I still have the 1200cc engine on the go, too. Depending on how it turns out I will have a choice of rocket special or high powered tourer.
                The other neat part is they are both 1980's so ALL the nitpicky parts are interchangeable ie; regulators, TCI boxes, coils etc, so I should always have one running.
                It also means I will have to order another set of upgraded Voltage regulator, SOFCA, and fuse block!
                '05 ST1300
                • xsilerating
                  • Dec 2006
                  • 430
                  • Eastern Ontario, Canada
                  Venture???
                  Did I miss something here?
                  Congrats on the new purchase. So ya joined the 2 XS'ive Xs's crowd and, like I and others, both '80's ... nice work
                  Now I'll know where to get parts when I need them
                  1980 XS11 LG (Diablo)
                  1980 XS11 G (Bagger)
                  1978 XS11 G (White Knight)
                  1978 XS11 G (Skeleton)
                  2016 SS (S.S. Flyer)
                  • Crazcnuk
                    • 2980
                    What did you miss?
                    Changed the oil and filter, cleaned the K&N air filter (came with it!) set up the clutch, lubed a few things, flushed the brakes, threw in some Seafoam, and went for a short ride.
                    Had to buy a new battery, and at first the starter was a bit stiff, but after a few starts it was firing right up.
                    I will have to get some pictures.
                    '05 ST1300
                      Wow 300 and a little time and your ridin. That is a sweet deal for sure.
                      • Crazcnuk
                        • 2980
                        Yeah, it was too good to pass up.
                        Unfortunately, I had to use the money for my insurance payment....
                        Hopefully, I get paid pretty quick.
                        '05 ST1300
                        • DJinNH
                          • Mar 2008
                          • 854
                          • New Hampshire
                          My bike has been sitting for a few months now due to winter. (XS1100SG).
                          I tried to start it up so a guy who is going to work on it could hear the ticking sound in the left side of the valve area.
                          I opened the fuel valves, opened the choke, hit the starter a few times as it turned but wouldn't fire up. Then came the waterfall or should I say "fuelfall". The gas came draining out of my airbox.
                          DAMN!
                          At least I got this guy to do the work for me while the bike is hibernating, much like myself.
                          Don
                          currently own;
                          1980 Yamaha XS1100 SG
                          2009 Yamaha Star Raider
                          • GARTHXS
                            • 1631
                            • Seattle
                            lets see it
                            Post some pics already
                            91 kwaka kz1000p
                            Stock
                            ( Insert clever quote here )
                            • Crazcnuk
                              • 2980
                              Last edited by Ken Talbot; 02-11-2009, 07:56 PM. Reason: removed extra set of img tags to let image display full size
                              '05 ST1300
