A TWIST on the electrial hook up.
OK .. The compressor says 15 AMP, 208 - 230 VOLT (+ / - 10%) 60 HZ, PH 1
I was under the impression that it would hook up just like a dryer but that's not the case. I took the wiring hook up cover off the unit to attach the dryer type plug and this is not a 3 wire + ground set up. It's a 2 wire + ground set up so now I'm really not sure how to hook it up. How the hell do I get the 208 - 230 VOLTS on 15 AMPS on a 2 wire hook up?
Any help would be very handy in deed.
Rob
Rob
and I just have the wire directly between the two...since they are so close to each other and all. That's a good project for this weekend, fix the wiring!
