Brake pedal identification help needed
  • Wildkat
    XS Special Gurette
    • Apr 2004
    • 3416
    • Location, Location
    I'm running a Mac 4 -2 system on Something Special... The way the system is set up, she needed a different brake pedal than stock as the stock pedal didn't allow any travel...
    Here's a pic of what she came with when we got her...
    I'm cleaning her up and would like to get a new one... anybody have an idea what this is from?
    If you need more pics... I can do that...
    Thanks for any help
    81 SH Something Special
    79 SF MEAUQABEAUXS
    81SH Nor'eas tah (Old Red)
    80 LG Black Magic
    78 E Standard Practice
    James 3:17
    “Alis Volat Propriis”
    Yamaha XS 1100 Classic
    For those on FB
  • blue giant
    • Aug 2007
    • 880
    • Ontario, Canada
    Kat,
    Have you considered taking a stock pedal and bending it to suit? I'm sure with a bit of heat and a gentle nudge you could shape your own with out ruining a good stock pedal.
    JAT.
    Paul
    Paul
    1983 XJ1100 Maxim
    1979 XS1100 Standard
    1980 XS1100 Special
    • Wildkat
      XS Special Gurette
      • Apr 2004
      • 3416
      We had toyed with the idea... but I wonder about the chrome if we did that... Wouldn't it tend to chip or peel with the heat?
      This pedal works perfectly (I think it might be off an early 80s Virago) as far as the shape... it just doesn't look all that great...
      I'm open to alternatives... including bending a stock pedal... I'm sure we have one or two (at least) around here somewhere that we could experiment...
      I just want it to be shiny...
      ohhhhhhhhhhhhhhh shiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiny
      79 SF MEAUQABEAUXS
      80 LG Black Magic
      James 3:17
      For those on FB
      • blue giant
        • Aug 2007
        • 880
        • Ontario, Canada
        Yes, you would want to be gentle with the heat and the bending.
        Send that one out for re-chroming!
        How expensive can that be?
        Paul
        1983 XJ1100 Maxim
        1980 XS1100 Special
        • Wildkat
          XS Special Gurette
          • Apr 2004
          • 3416
          That's not a bad idea, Paul... thanks! This one has some pretty deep scratches on it in some places that might make that a no go, though...
          I suppose if worse comes to worse... I can take a stock pedal... bend it and then have it chromed...
          Of course.. you know, if I chrome anything... it'll make the part next to it look shabby... and then one thing will lead to a thousand others... then it would eventually look like AKMac's Chrome Queen... hmmmmmmmm
          79 SF MEAUQABEAUXS
          80 LG Black Magic
          James 3:17
          For those on FB
            Rechroming is quite expensive from what most folks have stated!
            I just looked at the microfiche, and the 83 XV920 DOES look very similar to yours, it has a prominent bend near the shaft area. Perhaps you can look on Ebay and see some examples/photos of some being sold, might find a match!?
            • Wildkat
              XS Special Gurette
              • Apr 2004
              • 3416
              I found a couple of them from different Virago models on E-bay that are inexpensive enough to play around with... so not a bad idea TC... thanks!
              Has anyone else running these pipes experienced the same problem?
              just curious as I don't remember reading about it before...
              79 SF MEAUQABEAUXS
              80 LG Black Magic
              James 3:17
              For those on FB
                A few I just found!
                Hey Kat,
                Here are hopefully 3 working links to some examples with a decent angle of view to compare. Some are pricey....~$50.00, others are ~$20.00.
                Search parameters were "XV920 brake"
                PS, just checked, NEW price ~$65.00.
                  Thanks for any help
                  Hi Kat,
                  my cheapskate streak says, if it works paint it black & be happy?
                  OTOH, what should work for you is the brake pedal off a Yamaha 500cc Single.
                  It kicks out at two right angles to clear the pipe even better than the easy curves in the pedal in your photo and it's about the same length as the stock XS11 pedal.
                  The pedal off an XS650 also has the double bend but it's a few inches shorter which would bring it's pad too close to the footpeg to work nice unless you have really tiny feet.
                  • Wildkat
                    XS Special Gurette
                    • Apr 2004
                    • 3416
                    lol
                    I was just telling someone that I should get a decent one without scratches and maybe just paint it black... The problem with mine... REALLY deep scratches... so I still need (want) to replace it...
                    I'll check into those... thanks SO much!
                    79 SF MEAUQABEAUXS
                    80 LG Black Magic
                    James 3:17
                    For those on FB
                      I'm thinking.. (I know.. rarely.. and it's a scary thing) that if you wrapped it in rags to protect it against tool marks, you could bend one considerably without harming the chrome. Need me to come clamp it in your vice and break your table again?
                      Ummmm... A motorcycle!? (Bending over for the impending kick.. )
                      • randy
                        • Dec 2003
                        • 4521
                        Kat, I had the same issue on my 79F, the pedal would contact the pipe just enough so it bothered me. I got a pedal from a 750 special, it just arrived. It's perfect. Has a jog outward just next to the mounting boss. Clears the pipe beautifully.
                        • Wildkat
                          XS Special Gurette
                          • Apr 2004
                          • 3416
                          Hey Randy,
                          Thanks!
                          I ended up getting a fairly decent Midnight Virago pedal off eBay... I haven't put it on yet... but it looks like it will work perfectly...
                          Now we both have other options if we need to replace one in the future... yes?
                          (providing, of course, the one I have that looks like it fits perfectly.. actually fits perfectly... lol)
                          79 SF MEAUQABEAUXS
                          80 LG Black Magic
                          James 3:17
                          For those on FB
                          • Cobia
                            • Jul 2007
                            • 1587
                            • Palm Beach County, Fl
                            Limited travel
                            Hey Kat,
                            I have the same situation with the Jardine Spaghetti exhaust on my 79F. I only have about 1" of travel (if that) before it hits the pipe, impeding full travel. What I did is to push in (brace) the MC plunger rod before I installed the pedal, and when I installed the it that way it still provided enough travel to allow for the proper operation of the brake w/out blocking the relief port (spooge hole).
                            1980G Standard, Restored
                            Kerker 4 - 1
                            850 Rear End Mod
                            Automatic CCT
                            1980GH Special, Restored
                            '82 XJ1100 (Sold)
                            • Wildkat
                              XS Special Gurette
                              • Apr 2004
                              • 3416
                              Cool
                              thank you for the tip... I might check that out even though I do have the replacement pedal... We have a nice shiny stock pedal that could go on it...
                              ohhhhhhh shiiiiiiiiiiiiiiiiiny
                              79 SF MEAUQABEAUXS
                              80 LG Black Magic
                              James 3:17
                              For those on FB
