I recently ran a cat5 lan cable out to my garage. Cannot connect to my network thru it for some reason. Cable continuity tester indicates proper wiring. And I can connect thru the same port on the router with the same computer (laptop) from in the house so it would seem to indicate a cableing problem, except for cable tester which indicates that all is well. Any ideas anyone?
One possiblity that occured to me was the fact that my laptop is using a Linksys USB 10/100 network adapter. Is it possible that it doesn't send a strong enough signal to connect from that distance? Mind you, it's a distance of less then 100 feet so common sense indicates that's not the problem but when one is grasping at straws.....
