Hey Folks,
Okay, my sister-n-law that lives with "US", her car is a 2001 Chevy Blazer with a V6 FI....I think Throttle body style, has trouble starting after it's sat a few days, but with a STRONG BATTERY!
What I've done:
A few months back, replaced spark plugs, distributor cap/rotor.
Have run FI cleaner and Sea Foam in the tank when it would RUN.
Have had battery charged and used booster battery as well.
Recently rechecked for spark, have good spark "I THINK"... fat yellow spark!
Removed fuel filter, was flowing, could blow air thru with my mouth, but replaced with NEW anyways. Turned key on before completing fuel filter line connections, had fuel flowing into gas can, so fuel pump works!
Symptoms:
IT would turn and turn and turn with no sign of catching/firing for 20+ seconds! A few weeks ago, I learned to hold the throttle foot all the way down, that seemed to put enough fuel into it to get it to catch and finally got it to run. Once it was running, I drove it about 20 miles, no problems with accel, etc., and after stopping and turning it off, would restart easily!
I tried to get her to remember to start it every other day, but she's partially disabled, diabetic and bad foot, and we just would get busy, and it would sit for several days.
I've recently tried to start it, same symptoms, it occasionally acts like it wants to catch, but sometimes it would crank, rrrr, rrrr, rrrr, oomph, it would stop or severely slow down like it was firing during the upstroke of a piston's compression stroke??
Just recently the starter STOPPED responding to turning the key, so now I figured I've FRIED the starter motor, and will need to replace it, but this still brings me back to WHY it's behaving like this?
No warning lights had come on with the previous actual starts, no check engine light, etc.. I think it's got a throttle body FI design vs. individual port FI, which should be easier to use? I even poured some gas into/onto the throttle body butterfly, and tried to start it, but it still didn't help?
Regrettably, I don't have a MANUAL for it, I'll check the College online access we recently updated the username/password for, but would gladly accept and appreciate any other trouble shooting ideas!?
What I've done:
Symptoms:
