Paint Removal
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    Paint Removal
    I am striping the paint off my hop up bike frame today so the welding can be completed sooner rather then later. I strongly recommend that if you have a paint removal job to do that you skip the hardware store paint removers and go with aircraft coating remover. Check out the photos. That's how it looks at 10 minutes after application and only used 2 cups of the stuff.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    Hey Rob,
    I used the aircraft spray on stuff I got at the paint store, and was very pleased how well it worked. I found many rust spiders under the OEM tank paint that I would not have suspected or found if I hadn't taken it down to bare metal!
    • 79XS11F
      • 3563
      I haven't found anything unusual under the paint yet but how would i know.... This stuff strips paint almost as fast as you can brush it on. I have not seen it in a spray can in my neck of the woods yet but if it works as good as the brush on stuff it's worth every penny. a quick wash down is all my frame needs now :-) LOOK OUT ... the hop up bike will soon be back in the works :-)
      Rob
      1978 XS500E
      1981 Suzuki GS1100
      • Incubus
        • 1003
        • Austin TX
        You're right, the stuff is nearly miraculous. It works just as well, if not better, on powder coat. They sell the aerosol version at Walmart and Home Depot here in Baja Canada.
        Patrick
        XS11F (Incubus, daily rider)
        1969 Yamaha DT1B
        • blue giant
          • Aug 2007
          • 880
          • Ontario, Canada
          Fer Chrissakes don't get any on ya!!!!
          Lookin good Rob!
          Paul
          1983 XJ1100 Maxim
          1979 XS1100 Standard
          1980 XS1100 Special
          • hamjam
            • 1003
            • Toronto ontario Canada
            well... a long time ago when people uded to "P" me off ,I would pour a little brake fluid on to their hoods or fenders , on windshields I used WD40
            I have become much more mellow in my old age ;-)
            Seamus Ó hUrmholtaigh
            Niimi Moozhwaagan
            NOTICE: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been inconvenienced.
            Any connection between your reality and mine is purely coincidental.
            Member of "FOXS-11" (Former Owner of XS-11)
            and SOXS
            2008 Nomad "Deja Buick'
            • GARTHXS
              • 1631
              • Seattle
              wow!!
              Remind me not piss you off ,ok
              91 kwaka kz1000p
              Stock
              ( Insert clever quote here )
                Okay, Hammie, what does WD-40 do to windshields? I understand an oily substance smearing the view, but is that it?? OR does it cause the glass/plastic laminated layers to separate or such?? OR does it break down the natural rubber wipers??
                • 79XS11F
                  • 3563
                  Lookin good Rob!
                  No kidding Paul... even the smallest drop of this stuff starts to BURN immediately. I start at the bottom and work my way up to avoid being dripped on. I have e-mailed the lad who will be doing the welding so maybe ... just maybe the painting can be done early in the new year.
                  Rob
                  1978 XS500E
                  1981 Suzuki GS1100
                  • hamjam
                    • 1003
                    Hi T.C.
                    yes it smears the view ,and it soaks into the wiper blades and the only way to really remove it is to change wiper blades before cleaning the windshield or it keeps coming back
                    Niimi Moozhwaagan
                    and SOXS
                    • hamjam
                      • 1003
                      not to worry I have matured ....somewhat
                      plus I haven't met an XSive I didn't like
                      Niimi Moozhwaagan
                      and SOXS
                      • 79XS11F
                        • 3563
                        So I let the remover dry up on the frame overnight and removed it this morning with a course plastic scrub pad. That works well because in my sealed garage I can't be hosing the stuff off or slopping around the varsol. It looks like the first application took about 99% of the paint off right down to the steel. The areas that need a second coat are the areas where there was road grime on the frame and places I missed with the 1st coating.
                        I did find some lite surface rust on the steel in some places as TC had found on his fuel tank so I guess they (Yamaha) don't prep as closely as we would in their paint department.
                        Rob
                        1978 XS500E
                        1981 Suzuki GS1100
                        • thewiz
                          • Oct 2006
                          • 1115
                          • Wilksboro, NC
                          That stuff works so good ....
                          ... that you probably can't get it in California. Will have to bootleg it in from AZ or NV. There fewer tree huggers those states.
                          80G Mini-bagger
                          Past XS11s
                          • 79XS11F
                            • 3563
                            The frame is all wire wheeled up and ready to MEET HER MAKER tomorrow morning. I'll post pics when the job is complete :-) WOW .. I'm so happy to see this project on the move again!!
                            Rob
                            1978 XS500E
                            1981 Suzuki GS1100
                            • ossjughead
                              • 203
                              • Ottawa, ON
                              Hey Rob it look Great I blasted my frame befor i painted it glad i did cause i found some bad spots on the bottom of it. Had to replace some of it very small holes in it rusted but a easy fix. What year are you restoring?
                              http://i69.photobucket.com/albums/i7...all2008017.jpg
