Starter question 1978 1100
  • Del Tysdal
    • 73
    • Glyndon MN USA
    My starter is beginning to spin once in a while. Especially when the engine is cold and after sitting for a while. I am told the starter clutch is showing its age and use. I see in the manual that repair would include removal of the engine and a complete tear down. Sounds like I might as well junk it out or do a complete engine overhaul. What do you folks think? Deltysdal@aol.com
  • xswilly
    • Jul 2003
    • 462
    • Hollis, maine
    i have a 78 also
    and during the winter, when i start it up
    the starter will free spin a few times
    but only when it is real cold below 20
    http://home.securespeed.us/~xswilly/
    78E main ride, since birth the "good"
    78E Parts, the "bad" fixing up now
    78E Parts the "ugly" maybe next year
    79F Parts
    80G Parts
    75 DT 400B enduro
    • Del Tysdal
      • 73
      • Glyndon MN USA
      About 20 degrees F
      The starter spun quite a few times before it grabbed good to get the motor started. My son suggested I use 10/40 oil next year and not to 'tax' the starter continuously. Just be careful. Is there any 'oil additive' that will help.
        • 8928
        cold weather oil
        Might want to try a 5W40 instead of 10W40. The first number is the cold viscosity weight and the second is the warm; 5 being thinner than 10. These bikes tend to slip the starter clutch in cold weather, but 5W oil should help.
        • xswilly
          • Jul 2003
          • 462
          • Hollis, maine
          when the temps come back up to a normal riding temp
          lets say 50-80 degrees
          your starter will work ok and never free spin
          my bike is put away right now as the outside temps are about 20 here and light snow tonight about an inch
          followed by freezing rain,
          oh boy sounds like a nice drive to work tomorrow
          79F Parts
          80G Parts
          75 DT 400B enduro
          • Del Tysdal
            • 73
            • Glyndon MN USA
            5 w 40
            I will try 5W 40 next spring. Thanks for the suggestions. Best wishes to all.
            • boyat68
              • Oct 2007
              • 358
              • Virginia
              Del Tysdal:
              Just for kicks, try to have a fully charged battery the next time you try to start the beast in cold weather. This way it will pinpoint if it is the starter or the voltage, as these machines take a full battery to start properly. For example if the voltage is not sufficient to close the relay, engage the starter gear completely, and turn a cold engine, the gear may not engage fully and slip out and spin freely.
              • jeffe
                • Oct 2004
                • 393
                • Westerville,Ohio
                On more FYI. The starter on my 78E will do the same thing. Since I have been using Seafoam just before an oilchange per directions it is much better. Even before this it was a cold weather problem. My 650 Seca would do the same thing. It is a pretty immitation of Chew Bace!!
                78E ... Gone but not forgotten
                2006 Kawasaki Concours....just getting to know it
                • Del Tysdal
                  • 73
                  • Glyndon MN USA
                  Seafoam?
                  Seafoam in the oil? I use it in the gas tank for winter with a full tank of gas.
                  • jeffe
                    • Oct 2004
                    • 393
                    • Westerville,Ohio
                    Follow the directions. Put the called for amount in the oil just before an oil change. Either let it idle up to operating temp or take it for a very gentle ride, just a couple miles. I live about 3 miles from work, which is where I do my oil changes. I will put the seafoam in the the oil, take a nice easy ride to work and do a regular oil change. I do this every 2nd or 3rd oil change. Normally when I change the oil it is relatively clean looking coming out of the bike. When I do the Seafoam it is almost black. It appears to break up all the sludge and other build up in the crankcase, etc. It seems to help my clutch work better, less "grabby"and to help with the starter problem you described. I would just be extra careful to not put a heavy load on the engine when it is in your crancase. My 2cents
                    • Del Tysdal
                      • 73
                      • Glyndon MN USA
                      Thanks for the Seafoam tip
                      I will try this suggestion also next spring. We have 15 degrees F in Glyndon MN USA today.
