Touring Windshield
  • ardvark1
    • 135
    • Midlands UK
    Touring Windshield
    I've been reading bits and bobs on here about cutting and replacing windshields. Has anyone any pic's of a SF or the likes with a windshield fitted? I like the idea of having one myself but undecided which size to go for.
    Al
    • 6765
    Re: Touring Windshield
    Al
    Hmmm ..are you speaking of a frame mounted fairing like a Vetter Windjammer of are you talking abt a fork mounted windscreen?There are a few ppl here ,I am sure who have your model with fairings and or windscreens.On my '82 XJ 1100 I just mounted a Windjammer and the windsheild is quite tall...like 22".Its too tall to look over but luckily the quality of the windsheild is quite high and so there are no distortions in it.I am thinking of cutting the sheild down 3''-4" as to get better aerodynamics...heres a pic of my '82
    2005 Honda SilverWing 600
    2018 Honda PC-Xpress 150
    • egsols
      • Jan 2006
      • 1090
      • Barrie, Ontario, Canada
      I had the same problem with my vetter. I sat on the bike while a buddy marked a line just below my eye level. He cut it off with a angle grinder and bevelled the top nicely. Makes a huge difference, especially in the rain. The air flows over it and just catches the top of my lid, nothing in my face.
      Ernie
      • planedick
        • Mar 2005
        • 2068
        • Yorba Linda, California
        Cutting
        I have cut all the windshields I have had to the height I can see over and like egsols said, works great. I have also had special replacemnts made out of polycarbinate by my bro in law who runs a plastics company. When cutting, I cover the area to be cut with masking tape and mark the cut line then use a sabre saw to do the cut. I finish the edge with a file and sandpaper.
        Drilled airbox
        Tkat fork brace
        Hardly mufflers
        late model carbs
        Newer style fuses
        Oil pressure guage
        Custom security system
        Stainless braid brake lines
          • 8904
          smaller winshield
          Here's the windshield I run with on my '79 Special. It sits below eye level and throws most of the wind right over your head. They're about $70 clear or tinted.
          • egsols
            • Jan 2006
            • 1090
            Xsive status
            talk about rolling out the red carpet!
            Ernie
            • wa407mpp
              • Jul 2007
              • 717
              I've cut several windshields with a saber saw then used a grinder to finish them up, to add a professional touch run a propane torch over the edge a couple inches from the surface. Bikerpil, what did you use for saddle bag brackets on the black bike? Are they just the stock inside plates or did you make them yourself?
              Fastmover
              lion". SHL
              78 XS1100e
                • 8904
                saddle bag brackets
                Wa407mpp....I used 90 degree angle iron from Home Depot. On the bike, one end bolted to the shock bolt, the other end bolted to the stock turn signal mounting hole. Another angle iron bolted to the bag. The bag bracket sits on top the bike bracket and is attached with 2 bolts for easy 2 minute removal. I also added a custom bent piece of flat iron bolted to an existing hole on the frame to the bottom of the bag for added support. They are mounted a little higher than normal, (Kerker 4-1), but they don't interfere with the passenger. Also, I modified the lids with a hinge in front, stock latch in back, so they can't fly off accidentally.
                • ardvark1
                  • 135
                  • Midlands UK
                  The ones I'm on about are the smoked plain screens similar to the Harley types.
                  Al
                  • mstic2000
                    • Aug 2008
                    • 574
                    • Saginaw, Mi
                    I'm kinda partial to my setup with a National Cycle Street Shield. Mfg says, "will only fit Honda motorcycles"...........hehehe
                    My 1978 http://img.photobucket.com/albums/v518/mstic2000/xs.jpg
