Hey Folks,
I'm not electrical engineer, so I've got a question.
Background story: Fellow workmate's son moved to an older house while attending college. I had worked on his computer before. He said he had it plugged in and hit the ON switch, heard a POP and the magic smoke came out the back!
Brought it to me. Checked it out, bad POWER SUPPLY, put another used one from one of the many older units I had, booted and ran just fine! Gave it back to him.
Said he got it home, plugged it in, and hit switch, and POW, bigger popping sound, magic smoke release again!
Brought it back to me. Took apart, heard something rattling, pulled power supply out, took cover off, and there was a CAPACITOR that had gotten BLOWN off the circuit board!
There were also several others that were FRIED!!!
Put in another spare Powersupply, but this time, it didn't come on, NO POWER lights, NO post sounds, no beeps, NOTHING!
It is an older P4/2.4Ghz/533 MhzFSB on an MSI MS-7005 Mobo. I tried another Power Supply, and it also did NOTHING!
1st question is probably obvious answer....with a failing/blowing power supply, could it send a damaging surge thru the 20pin connector to the MOBO and FRY something on it to kill it?? OR...would it more likely kill the CPU?
I have told the coworker that her son/they will need to have the wiring of the old house checked out. Don't know if they might have the outlet wired wrong, possibly 220?
2nd question, could having the outlet wired backwards, common and hot backwards....cause the powersupply to get damaged?? I know it's AC current, but they have those fancy different sized plug ends to keep the polarity correct, but would it really cause a PS to immediately fry???
I have pulled the Hard Drive and video card, and have tested them on another system, and they seem to be working, but I don't have a MOBO that can handle the P4 to test it on. WE do have some P4 systems at work. I don't know what the FSB ratings are, but IF they are slower than the 533 that the CPU requires, will it work like Ram and just run slower....so that I can TRY TO TEST the cpu on the other system, or will it damage the MOBO or CPU trying to run it on a system mobo that ie. only runs 400 Mhz??
Thanks in advance!?
Thanks in advance!?
