off idle stumble fixed but
  • petejw
    • 2269
    • sydney australia
    ive got a 4 into 1 with a fairly open exhaust,
    im running 150s atm, but slightly big, going 2 140,
    ive run up2 160 mains screamed from 6000 - 8000
    at wot, but bogged down at lower revs.
    buy urself a drill bit kit from a hobby store, about $35.
    with assortmant of bits, makes it a lot cheaper.
    wat pilots have u got, hav u got the needles shimmed?
    im running 38 pilots
    needle shimmed with 3 washers.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • red bandit
      • 957
      • central michigan
      I work in a machine shop, no need to buy drills.
      I have 38 pilots. No shims.
      I like to have diff jets so I can go back if I want to. Once you drill there's no going back. Not knocking you. Just diff.
      79 SF parts bike.
      • AlanB
        • Oct 2006
        • 705
        • Scotland
        Hi Guys,
        If you are drilling jets and go too big, you can solder 'em up, and start again!
        Don't fill the entire "cavity" in the jet; the internal shape need to remain, just try to block the actual hole.
        AlanB
        If it ain't broke, modify it!
        • egsols
          • Jan 2006
          • 1090
          • Barrie, Ontario, Canada
          Hey Pete,
          Just thinking.....are those keihin's used on a specific bike? If they are, have you checked if there is a forum for them? Maybe someone else has had the same issues
          Ernie
