pan head screw size
  • old_bartender
    • Apr 2004
    • 41
    • Minnesota
    pan head screw size
    Time for carb kits, i have read that it is a good time to replace the pan head screw on the carb bowls. I plan on allen head bolts,
    so what size and length will i need to order.
    i want everthing on hand
    thank you
    old_bartender
    If you spend to much time with me at work. then park it and cab it!!!
  • tarzan
    • 1700
    • Chandler,Az.
    I believe those screws are M6 x 1 x3/4
    80 SG XS1100
    14 Victory Cross Country
    • AlanB
      • Oct 2006
      • 705
      • Scotland
      Hi OBT,
      Mine are M5, but there are different lengths in different types of carb; best to pull one out of the bowl and a couple from the tops (different length screws in the tops between tin and ally caps, and longer ones to clamp the throttle-cable plate!)
      You need to check!
      AlanB
      If it ain't broke, modify it!
      • XSPastor
        • Oct 2007
        • 602
        • Gaithersburg, MD
        There's a company on ebay that will sell you a set of stainless smooth headed hex screws that will replace the bowl and vacuum diaphragm cover fasteners. Just search XS1100 stainless on ebay. You'll pay for the convienience but if you just want 'em and don't want to drive all around town looking...
        Tim Ripley - Gaithersburg, MD
        23mm float height
        120 main jets
        42.5 pilot jets
        drilled stock airbox with K&N
        Jardine 4 to 1 Exhaust
        spade fusebox
        1st and 2nd gear fix
