starter solonoid
  • bobberbetty
    • Jun 2008
    • 21
    • the open road with a hot motor between my legs
    starter solonoid
    ok there are 2 wires coming out of the solonoid. one red and one black. the red one goes to the positive terminal on the battery, where does the black one go? it isnt long enough to reach the negative terminal. is it ground?
    1978 XS1100E 81' motor
    ratted out piece of lightnin. yeah.!
  • FJ111200
    • Oct 2007
    • 317
    • Crewe, Cheshire, UK
    I think it goes to the wire going to the starter button.
    • bobberbetty
      • Jun 2008
      • 21
      well that wire is only about 8 or nine inches long so there isnt too many places it could go.
      • FJ111200
        • Oct 2007
        • 317
        OK,well look for a wire of the same colour coming out of the loom near to where the solenoid is. Connect them up and that should be it. Obviously a wire 8 or 9 inches long ain't gonna stretch to the starter button itself eh.
        • planedick
          • Mar 2005
          • 2068
          • Yorba Linda, California
          Starter button
          The starter button just completes the ground causing the starter to run. If you touch that black wire to ground the starter should run.....
          Drilled airbox
          Tkat fork brace
          Hardly mufflers
          late model carbs
          Newer style fuses
          Oil pressure guage
          Custom security system
          Stainless braid brake lines
          • randy
            • Dec 2003
            • 4521
            Hold on.
            There are FOUR wires off the solenoid.
            Two small gauge, red/white and blue/white (could be blue/red). they plug into the wiring harness nearby the solenoid.
            Two heavy gauge one red, one black. I think these are the wires that you are questioning?
            If so, the red one, like you said goes to the positive side of the battery, the black one goes to the starter motor.
            I have also seen solenoids with FIVE wires, an extra small gauge wire for the ballast bypass.
