sometimes insanity rules...possible mod!
  • geniusloerts
    • Jul 2007
    • 420
    • fayetteville, Arkansas
    ok, so i was looking at a friends bike today and what he would need to do to get a little more rumble out of it.
    Anywho
    so i got to looking at his bike which is a '07 Vulcan 1300... caught a glance if the swing arm assembly...... hey thats shaft drive......so is my bike.......hmmmmm .....that it is a little bit longer and can handle quite a bit fatter tire, not to mention it has some nice aluminium wheels......
    soooooo my thought was to research the swing arm assembly and maybe do a swap....i could run one fat tire...hehehehe.
    What do you all think?
    1979 XS1100 SF "Black Goblin"
    -Pod Filters
    -4-1 pipe
    -larger jets for carbs
    1982 XJ1100 "Black Sheep"
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    fat tire with shafty
    Definitely doable, you will have to cut out the left pivot or machine a new one and weld it to the outtermost left of the frame there so you can get the wider swingarm in. then you have to get a spacer cut for the middle drive and an extender to the middle drive shaft splines. It really isn't that difficult if you can weld...couple of members are already on it....chop
    MDRNF
    79F.....Not Stock
