Well, yesterday sucked. Riding home I completely lost 2nd. I had just shifted from first into 2nd and while it didn't lock totally it almost did and I could not get it out of 2nd. I lurched to the median and shut it down. Tranny totally locked. Knowing that I tanked something already I gave the lever a swift shove down and it dropped out of gear. I started it up and inched my way home and parked it. During the ride, 2nd would chatter like hell and not stay in gear, I then just skipped it and went to 3rd. There was a bit of chattering in 3rd also.
I started the tranny removal. (not to self......ensure you follow the first line of the directions remove oil pan) I got it to the point of pulling the gears and couldn't, so getting in touch with my feminine side I went to re-read the directions and realized I missed the first line about removing the oil pan. I will do that tonight and pull all of the gears out.
The question is what damage am I looking at? Will the Dremel fix still work or should I just go order new gears for it?
covering the 1st and 2nd Dremel/die grinder fix technique....scroll down from the MAIN FORUM PAGE, you'll find newer ones that are NOT linked from the left column!
Inspect the shift forks for signs of Xsive wear where it contacts the gears, but you only have the choice of buying new ones!
