In case anyone was wondering whatever happened to me...
  • CarolynS
    • 369
    • Massachusetts
    Dropped off the bike on the 16th with Ed-the wonder mechanic. He said at least 3 weeks til he could get to it. No problem.
    He calls 5 days later and tells me to bring him the head from the 79. I had already ordered the gaskets, figuring I'd need them anyway. Those came in from PNM on the 23rd. I was beginning to wonder if they would ever arrive...
    Took the head to him on the 24th, and the gasket set. He had some questions for me as to what kind of oil I wanted to use-told him whatever he thinks is best is what I'll go with-. I mentioned the fact that syn causes clutch slippage-he says only if it contains certain elements such as Moly-that should start trouble here. He said he will write down everything I'm going to need to know for the future. He wanted to know what any other plans I had were. I told him about lowering it-he's giving me the 11.5 shocks for that-. He said we'll cap off the air shock and give me another 1/2 to 3/4 inch to drop it down. He wanted to know if I wanted the fork seals done, as they are leaking-one profusely. I said I'd need to order the parts. Nope, he's got them there. Did I say I love this guy?...
    He's already cleaned the rest of the engine up. Said it was the worst case of neglect he's ever seen. The outside looks great, but inside he doesn't think the oil was ever changed. Said it was more like tar than oil. That has now been remedied along with a new filter. He sees no other damage from the valves bending. All of them were bent-along with two busted valve guides-serious damage.
    He looked over the 79 head and says it looks good. That bike does-well, did-run(until I tore it apart. How fun is it to work on these things?! I was having such a good time working on the bike, I didn't stop at the head. It is now a rolling engine holder. Everything has been removed and labeled to be stored for later use if needed. HWMBO was with his kids and I was unmolested in my demo project. I had a ball!)
    Ordered the new cam chain on Tues from Z1 Enterprises. It arrived yesterday! I will call Ed tonight and drop it off to him. The chain was $20 and the master link was $1.34! I couldn't believe it!
    I don't know how soon he'll be done with the bike and I really don't care. He can take as long as he needs. Knowing him though, he'll call me next Wednesday and tell me to come and get it-so much for 3 weeks til he can get to it.
    So I rattle-canned my fuel tank and sidecovers. Nothing special, but I wasn't going to ride around with old crackle coated lacquer for the summer. It will go for a 'real' paint job this winter, when I can drop everything off at my mom's and have access to the compressor and the air brush, fiberglass gear, etc. I got plans for her and the Vetter fairing...
    I still have to swap the tires out,even though the rims on the 79 look terrible, the tires are almost new. And I still have a few bugs to chase out of it-left turn signal won't work, having the center stand cut down, reattaching every disconnected lead, etc. No big deal when compared to what I started with, and my lack of knowledge at that time. I'm am learning steadily thanks to all the folks here.
    It's not long now. John will ride it home from Ed's. He'll put her through her paces without hurting her or himself.
    Can't wait to get her home!
    80 XS1100G w/ Windjammer-the Witch
    79 XS1100F
    "Look Ma! No hands!...."
    That will be the clencher... you'll never get it back.
    • BlkMage
      • 209
      • Carson City, NV
      Re: In case anyone was wondering whatever happened to me...
      Good luck with that, I had to do a LOT of rewiring when I got mine. Eventrually I cut the plug for the flasher unit out of the original harness and ran a new wire from the fuse box to there to the switch box on the handlebars. And that was just the start...
      1981 XS1100S (former)
      2006 Suzuki Katana 600 "BLKMGE"
      • silverarrow1970
        • Mar 2008
        • 23
        • Beatrice, NE
        You really don't need a left turn signal.
        Just turn right all the time.
        Jon
        '80 XS11 SG "My Serenity"
        • CarolynS
          • 369
          • Massachusetts
          Yeah, I know...
          Once he rides it I may be in trouble, Tod. You're right. Sometimes he gets a little wild and likes to do burn outs on his HD-I'm already prepared for him to try to do one on the Witch. I can hear it now-'Baby, let me see your bike for a minute...'
          NO WAY, Buster!!! I'll give him what he calls my 'excorcist' look-he'll wither....
          Turn signals...yeah, I'm looking forward to that. NOT. I absolutely despise electricity and wiring. I'm always the one that gets shocked, and it bugs the crap out of me. I know, I know...electricity is SO simple. I've heard it all before. Believe me, I understand how it all works, I can read a schematic, etc. I just hate it. I'll start by cleaning all the connections, checking everything and of course it will be something hidden-yet simple-and I'll be here calling for help, and feeling like an idiot when someone points out the obvious cause in 2 seconds. AaaRrrgggghh!
          I plan on making some changes to the lighting anyway this winter-no not LEDs-I may as well get used to the system now.
          With any luck, I'll be posting pix next week of the old girl ready to rock and roll.
          79 XS1100F
          • Flatlander
            • 288
            • Michigan, Thumb
            No need to worry too much about getting a electrical shock on the bike though.........unless you are holding onto the end of the spark plug wire while starting or running the motor.
            So.....Go for it. And good luck.
            P.S. If you are still nervous about getting a shock or shorting out something, then remove the battery, which I recommend you do when making replacements or repairs to wiring.
            He may even (try) take over the bike anyways when the two of you line them up and the old XS out does the HD.
            It's a male thing! You may not completely understand this.?.
            Flatlander
            '81 XS11H
              Re: Yeah, I know...
              Hey CarolynS, that's great, BUT we want to see photos of the BIKE!
              Yes, what Flatlander said, just remove the battery, or disconnect it's (+)terminal, and that will keep you safe! Being able to read a schematic is more than many of us can do! But like you've already read on here, cleaning the contacts is a major part of eliminating most electrical gremlins. Poor grounds is the most common problem for poor/no turn signals. Secondly is a failed flasher, as well as damaged wires in the switch housing.
              Why no LEDs?? They can free up many amps to use for additional driving lights or other accessories! JAT!
              Hang in there, you'll be riding that thing soon!
              • CarolynS
                • 369
                • Massachusetts
                Why...I oughta!....
                Very Funny! Besides, THIS ol' girl 'shimmies'-bellydancer I still am after all.
                Boys, if I remove the battery when I go to check things-how will I know it works?????
                It's just a phobia-like bees and heights-I can deal with them, it's just not my favorite thing to do. Tolerance, patience, Cap't Morgan...(woops! That comes after).
                No, I get it. I will clean everything, make sure it all contacts where it's supposed to and not where it's not supposed to(grounds, shorts). Alas, the plague of time-we all feel it's pinch-and it's corrosive effects!
                I know one thing for certain about this bike-I'd better bring tissues when I go to pick it up! I'm so excited about having it to play with again, but this time I get to hear it run and ride it. I didn't think when I started down this road, I'd end up so attached. I figured it would just be something to have fun on and not have to wait to get 'taken' riding. It's become so much more than that-partly due to the friends I've made here. I know as I put more time and love into it, my efforts will be rewarded.
                Thanks for the continued support and friendship. You all rock!
                79 XS1100F
                  • 7807
                  WRONG!! Do NOT disconnect the positive + side!! ALWAYS disconnect the NEGATIVE - side FIRST .
                  Jezz TC, try and get her to weld with a battery, instead of fixing it!
                  I know, you just want to see her "dance", but do be kind to her!
                  • Wildkat
                    XS Special Gurette
                    • Apr 2004
                    • 3416
                    • Location, Location
                    You think you're attached now?
                    Just wait until you get her on the road!
                    and ummm... definitely the negative cable first... The only time I would ever recommend being negative before positive...
                    (somehow, I think she already knew that one though)
                    81 SH Something Special
                    79 SF MEAUQABEAUXS
                    81SH Nor'eas tah (Old Red)
                    80 LG Black Magic
                    78 E Standard Practice
                    James 3:17
                    “Alis Volat Propriis”
                    Yamaha XS 1100 Classic
                    For those on FB
                      So to get this right...
                      "Your hair looks really nice today, but your face looks like it was hit with a MAC truck"
                      Is more correct than
                      " Your face looks like it was hit by a MAC truck!! BUT.. your hair looks nice today."
                      I want to be politically correct here...
                      • Wildkat
                        XS Special Gurette
                        • Apr 2004
                        • 3416
                        Once again, Dear...
                        you missed the point a bit... Go see what the wife says about that one and report back to us...
                        and not to encourage you or anything... but...
                        that WAS funny!
                        79 SF MEAUQABEAUXS
                        80 LG Black Magic
                        James 3:17
                        For those on FB
                        • CarolynS
                          • 369
                          • Massachusetts
                          On Being Negative...
                          Poor TC! One typo and your DONE!
                          Negativity is the thing to get rid of...I always do that first, both literally and figuratively. But TC is right, and he is kind enough to recognize I have some mechanical aptitude, I DO have to remove the positive side when I take out the battery(that's what you meant, right TC?).
                          79 XS1100F
                          • Flatlander
                            • 288
                            • Michigan, Thumb
                            T.C. was thinking about something else at the time.?.
                            In his defence, I think what he was thinking about, at the time he mentioned the positive terminal, the old Dodge's positive grounded system.?.
                            Flatlander
                            '81 XS11H
                            • CarolynS
                              • 369
                              • Massachusetts
                              That's what I love
                              Everyone here likes to tease and be included in the latest...
                              What a great bunch!...
                              I will call Ed-the wonder mechanic-in the morning while HWMBO is running to the yard for his chores. Hopefully, if he's not too busy, I can drop off the cam chain to him, and we'll be under way soon.
                              I will go down to the yard and finish stripping the 79 down. I need the tires now. I'll just swap rims and tires together. Plus, put another coat of paint on the fuel tank and side covers.
                              79 XS1100F
