Hi Gang. Last fall I found a brand new front master still in the OEM box. Swapped it in. Bled both lines. Solid feel till yesterday. The brake lever almost went back to the grip on a routine stop. I pumped it once, and it felt fine. Went directly to my friend Pats house, (yamaha mech.) and found no leaks, no loss of fluid no stuck caliper, and no stuck piston. The front wheel turns freely. However I now have about 1/4" of free play in the lever. Its not the lever adjust, as the stop nut has not moved. Its almost as though the piston is not coming completely out of the master cylinder, but every thing works. Its a very weird feeling. Knowing a bit about physics, I cant think of a scenario of how this could be possible. As I said, no drag on front wheel & pads look great. Help?
Floyd
'80G
Floyd
'80G
