this is from Sport rider regarding the ZX9:
THE ZX-9R SYSTEM
Kawasaki's ZX-9R uses a relatively straightforward system compared to the 1995 Honda CBR600F3. Twin vents mounted beneath the headlight channel air via ducts running over the frame beams and into a sealed airbox. Look closely, and you can see two smaller nozzles behind the grilles which connect to the carburetor float bowls. Their function is to equalize the pressure between float bowls and airbox; without them the higher pressure of the incoming charge would upset the carburetion, potentially blowing fuel out of the bowls and tending to push fuel back down the jets, causing mixture leanness. Kawasaki uses much the same system in all its ram-air machines, though the ZX-7 and earlier ZX-11s have a single inlet only.
http://www.sportrider.com/tech/146_9508_ram/index.html
Our bikes may never see high enough speeds to create a problem...but I would still do the venting if I put on ram air.
THE ZX-9R SYSTEM
