Special fuel tank capacity
  • Special fuel tank capacity
    Today I filled an empty Special tank and it held preciesly 3.946 gals. I filled it to the very bottom of the filler neck tube, just like I do on my bike. I have never been able to put any more than 3.5 gals in mine and that was when it seemed to out of gas, coasting into a gas station. I guess there is the equivilent of a quart that cannot be drawn out.
    (Ok, so I forgot to add "Per Side)
    A really BIG quart... like 2 of them! lol.
      Most I've got into mine has been 3.2
      that's been right after going to reserve.
      mro
        Should hit reserve at 3.5 gallons empty at 3.9 and change
        " That glass isn't half empty it has a hole in it "
        79 SF set to cruise
        80special work in progress
        and now 78 needs work
          Hi John,
          3.946 gals?...... .946! Jeez, you need to get out more!
          AlanB
          If it ain't broke, modify it!
            Originally posted by AlanB
            Hi John,
            AlanB
            But I did get out...to the gas station. I had treated the tank from the Bag Lady, and I wanted to know excactly how much fuel it would take to fill it. Kat drove me to the gas station, so I could hold the tank and prevent spillage on the ride home.
            The Clymer manual says the tank is 3.9 gals, but I never believed it was that big. I wanted to find out for sure.
              capacity
              John ,
              I once rode slowly to station and put 3.9999 gallons in my 80XS1100SG.
              Pump could have some inacuarcy in measuring. Also I have added some extra fuel line and 2 inline filters, having bypassed the octopus.
              I have also rode into station and put 5.434 gallons into a "5" gallon tank on my HD road king. I asked the guy making the tanks at York, PA about the stated versus the actual capacity. He indicated that there was indeed some variation from tank to tank.
              At least you know now.
              Happy motoring,
              Brent in GA
              [/QUOTE]
              Brent in GA
                I put 4.037 in my Special once this summer. I drove it into the gas station and shut it off but it had to be running on fumes.
                Bob
                #1 ’79 XS11 Special
                #2 ’79 XS11 Special
                '97 V-Max
                '01 Dyna T-Sport
                  Correct me if I'm wrong but is the volume for the tank not based on water at 68 degrees? I think that the pumps are also calibrated at 68 degrees so their measurements, when correct, can vary at different temps. On my old Ford with dual tanks I used to run one tank dry all the time and it never refilled to the same amount!
                  Ernie
