where to get new coils
  • timeless-cowboy
    • May 2007
    • 25
    • akron ohio
    ok Ive looked a little and have had no luck so far. where can i get new coils and possably a new pickup coil
    1980 xs1100
    1981 xs 400
    1982 verago 750
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    There's a few new ones listed on Ebay.
    BDF Special
    • 79XS11F
      • 3563
      • Ottawa, Ont. Canada
      If money is not an issue you can get them from your Yamaha dealer but if I am not mistaken they only sell the entire timing setup as a unit. Very pricey too, Also e-Bay as was mentioned and you should be able to get them at Bike bandit possibility old bike barn but they will be after Market units.
      It's a lot cheaper to repair the ones you have unless the wires are broken off right at the pickup body. A soldering iron and some wire is a lot cheaper and works fine.
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
        Hey Cowboy,
        Follow this link to find out about getting affordable replacement ignition coils!
        The PU Coil(s) are still available from Yamaha/bikebandit.com, but are a bit pricey:
        3: PULSER COIL ASY 22830-001 $140.61
        What's interesting is that BB lists the PU assembly for the Special as available, but they don't list it in the 80G parts list!?!?
        SO...as has been mentioned, the PU coils themselves rarely go bad, but the wires DO, and the instructions in the tech tips are pretty good in explaining how to fix them! Same thing for the ignition coils, the wires can be replaced...again, tech tip info. But the ignition coils can burn out, short internally, even intermittently due to expansion from heat! Testing info also in tech tips!
        • timeless-cowboy
          • May 2007
          • 25
          • akron ohio
          coils
          thanks for the info guys im just looking to rebuild the ignition system this winter i would like to make it like new with a couple strong coils
          1980 xs1100
          1981 xs 400
          1982 verago 750
