Questions about FJs / Xs
+ More Options
Posts
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    The FJ1100s and 1200s are chain drive bikes ... right? If so are they closely based on the XS engine? If so is there a different and separate part, transfer case where our middle gear is? If so is the bolt pattern the same ... or in other words .. would it bolt right onto our engine where our middle gear is?
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
  • Wildkat
    XS Special Gurette
    • Apr 2004
    • 3416
    • Location, Location
    Nope...
    XJs are shaft drive... the engine is basically the same (I believe) as the XS... otherwise... there might have been a huge mistake made when Tod did the 750 final drive modification to his XJ...
    81 SH Something Special
    79 SF MEAUQABEAUXS
    81SH Nor'eas tah (Old Red)
    80 LG Black Magic
    78 E Standard Practice
    James 3:17
    “Alis Volat Propriis”
    Yamaha XS 1100 Classic
    For those on FB
    • Wildkat
      XS Special Gurette
      • Apr 2004
      • 3416
      Wait a minute.... did I read that right?
      or did I speak out of turn (again)?
      Don't listen to me... I'm just here for comic relief...
      79 SF MEAUQABEAUXS
      80 LG Black Magic
      James 3:17
      For those on FB
      • Wildkat
        XS Special Gurette
        • Apr 2004
        • 3416
        Oh hey now!
        You're changing this up on me now!
        The FJs ARE chain driven... this I know for certain...
        (WooHoo! Yea for me!)
        Not so certain about the rest as I believe the FJ works in stranger and more mysterious ways than the XS... but I will defer that to those in the know...
        79 SF MEAUQABEAUXS
        80 LG Black Magic
        James 3:17
        For those on FB
        • 79XS11F
          • 3563
          Hey Wildcat .. Yes I edited my post when I saw my own mistake so your OK .. no worried :-) Anyway I was over at Bike bandit looking at the cases for the FJ and there dose not appear to be a big difference at the back end where our middle gear goes. I bet you can see where I'm going with this ... I have never seen a FJ up close and always wondered if parts from the final drive could go into XS cases or bolt on to have a FACTORY XS chain drive modification.
          Rob
          1978 XS500E
          1981 Suzuki GS1100
            Kat dear.... put the bottle down now and go on to bed.
            I think this is something we need to find out. Maybe that could be our weekend project... totally strip Kat's FJ (I said the bike Kat!) and stare blankly at all the little pieces... then go home? She has a running XS now anyway... she doesn't need that thing any more.
            • audijunky
              • Apr 2006
              • 707
              • VA
              I was just looking at a photo of an 86 FJ1200 and it looks like the starter is different, however the engine looks to be built the same and the area where the front sprocket would go looks to have the same dimensions as our middle gear housing. Have a look
              79 XS1100 modified standard
              straight pipe 4-2 exhaust
              Owned 83 Honda V65 Magna
              Owned 02 Vstar 650 classic
              owned 85 Honda Shadow VT 700C
              • audijunky
                • Apr 2006
                • 707
                • VA
                While were on the subject .... why not put the entire engine in an 11??????
                • 79XS11F
                  • 3563
                  Well the early XS1100 engines are more powerful overall ar they not? I also don't have a FJ 1100 or 1200 engine laying around.
                  Rob
                  1978 XS500E
                  1981 Suzuki GS1100
                  • webbcraft2150
                    • Sep 2002
                    • 1605
                    • AUSTIN.TX
                    Rooooaaaad trip!!!!!!!!!
                    • 79XS11F
                      • 3563
                      Yes it is very similar in appearance and size and the fich of the FJ cases also look very similar. It would be far less costly for Yamaha to make the change there as compared to redesigning the cases. I am just curious if the XS could receive an FJ final drive that ether bolts right on or can be installed easily if /when cases are split. It would sure be a lot easier then messing around with making your own output parts.
                      Rob
                      1978 XS500E
                      1981 Suzuki GS1100
                      • pggg
                        • 1609
                        • NZ
                        Pretty sure there's too many differences between the two engines for an easy bolt-on swap, you'd still be looking at a major project.. and actually the shaftdrive is one of the elevens best features anyway... smooth, clean,quiet, clean, no maintenance, clean... what person in their right mind would WANT a dirty greasy chaindrive?
                        • 79XS11F
                          • 3563
                          I was thinking for my next project bike. If it was an easy switch out I would do it to get the extra horses to the ground. After all .. Yamaha did the same thing when they made the FJs.
                          Rob
                          1978 XS500E
                          1981 Suzuki GS1100
                          • pggg
                            • 1609
                            • NZ
                            Hi 79, yeah for normal road riding those extra ponies don't really come in to play unless you're hard-out full throttle everywhere! Shaft versus chain, getting power from the crank to the rear tyre, the difference in efficiency between chain and shaft ain't as much as some would have you believe... there IS a difference, but not huge...
                              I have been elbow deep into both the XS and FJ engines, and I can tell you the only thing they have in common is the crankshaft main bearings. The FJ engine is a 4 valve per cyl engine, and it rotates backwards compared to the XS. I'm sure somebody somewhere could find some way to graft some kind of middle drive to an FJ engine.
