Looks like new guy at work(rides a 81 virago] is going to give me a cb350 and local pilot is going to sell me 2 cb350's for a total of $50.00. Think i got a chance of 1 good one?
winter projects
I had a CB350 for a few years in the early '90s, complete with MAC exhaust system. One thing comes to mind...stock rear shocks were pretty bad, even when new. You should plan on replacing the shocks, as I doubt if any of the 3 bikes you are getting will have decent ones on them. Other than that it was an OK bike, nothing outstanding. Good bike for commuting and utilitarian use.
Like many old bikes, the engine may be sound but everything else will need work. I found it best to plan on spending $500.00 for any bike to put it in reliable working order. Price includes:
Both tires
Chain and both sprockets
Air Filter
Brake pads/shoes, front and rear
Brake hoses
Change of fluids (oil, brake)
Registration
Battery
Duplicate ignition keys
Misc parts, like fuses, lights, cable lube, carb cleaner
Shop manual
Spark plugs
You may also need carb parts, but with 3 bikes you should find enough usable pats to make up a full set.
Two other areas to look at: Swing arm bushings and front brake calipers. You may need to get new bushings installed and rebuild a front brake caliper.
On the other hand, you may get lucky and have enough parts/pieces, or a bike that is in goos shape to start with, and get one of the 350s on the road with minimal expense. Let us know what you end up with.Jerry Fields
'82 XJ 'Sojourn'
'06 Concours
My Galleries Page.
My Blog Page.
