Long term storage
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    Long term storage
    I'm looking for suggestions on storing a bike long term. Not for the winter but to be parked for years or even decades.
    Anything different to be done if the bike is new as opposed to one with many miles on it?
    Seeing the MNS on Ebay with 30 miles on it got me thinking.
    I know the battery should be removed and some kind of lube to coat the cylinder walls.
    Gas should be drained but how to avoid rust in the tank?
    Also, should the oil be drained?
    This isn't going to happen to either of my XS's. They remain on the road.
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
  • BLUEJEEPLAB
    • Sep 2005
    • 703
    • Miami Valley, Ohio
    You would need to consider the environment too. Ideally, a temperature/Humidity controlled room with no UV. This would minimize issues with rust and dry rot. The bike should be on some sort of stand so the tires are not in contact with the floor. Periodic checks and rotation of the engine, tranny, and wheels would keep them from freezing up. I'd say proper oil and drive fluid levels are essential.
    A good coat of some sort of wax on all glossy will help preserve appearance. Likewise, armour all or other protectant on vinyl and exposed rubber. A good fitting cover helps shield the finishes from scratches and what not.
    What about effects of the long term storage on brake lines and such? What does brake fluid do with periods of no activity?
    My two cents...
    Papa Gino
    79 and something XS 1100 Special "Battle Cruiser"
    78 XT 500 "Old Shaky"
    02 Kawasaki Concours "Connie"
      • 7807
      Pat,
      I would use a "fog" spray oil on all the surfaces. Marine grade oil would be best. If you are going to just "put it away", look into the "shrink wrap" option. I think they are now using nitrogen to remove most of the O2. This would probably be the best option for long term.
      • desert1
        • 750
        • Grand Desert, Nova Scotia, Can.
        I gotta ask
        Storing for decades. Must be going on a real long vacation......anyway put the bike somewhere warm, no condensation, run it every couple of months, keeps the seals lubed, battery on trickle charge......I couldnt be without my 11 for a year!
        Bruce
        Bruce Doucette
        Phone #1 902 827 3217
          Long term storage
          Dontcha just love those movies where folks resisting alien invaders discover a military stash that's been hidden for centuries and the tanks and planes still work? For long term storage, clean & wax, drain all the fluids and coat all the innards with inhibiting oil, remove the battery, prop the bike up on a stand so niether tire is touching the ground, store at a constant 60ºF in the dark in a dry nitrogen atmosphere.
          So, whatcha storing & why?
          Fred Hill, S'toon.
          • HobbyMan
            MeatHead Idiot "GURU"
            • 1801
            • Colleyville, TX
            nothing is better than cosmoline. How many rifles have I discovered that were packed away in perfect condition. Since I am going away to college, this thought has been crossing my mind. Use something like the marine engine fog. I would drain the tank and place the whole bike in a sealed bag. I read an article one time about a car that was found in a barn. I can't rember the type of car it was but aparently in the 60's some dude bought a brand new car and put it in a large sealed bag. It had the original break in oil in it. The interior still smelled like it did rolling out of the factory. I wish I could find that article again.
            Acta Non Verba
            • MartyA
              • 2148
              • NW PA
              BLUEJEEPLAB says "...You would need to consider the environment too."
              Keep it away as best as you can from barns, cement/metal buildings, shelters that naturally have extreme environments. Barns can have a long term supply of ammonia.
              Cement and metal buildings get cool in the evenings and warm up during the day. I saw a buddy's bike dripping from that type of environment in the early spring following a long winter nap.
              A secure wooden garage with a wooden floor that has no windows or sunlight exposure is a good thing. Temperature extremes in a wooden garage are not too bad. It would be the most cost effective method, as you would need minimal environmental controls.
              Cover the bike on top to keep dust from settling too much, but don't enclose it. Cover the holes, the gaps, the little caves! Exhaust pipes, air cleaners, intake ports, handle bars, under the seat are all little living quarters and little storage caves for little animals. Store the seat off the bike.
              Marty in NW PA
              This IS my happy face.
              • HobbyMan
                • 1801
                • Colleyville, TX
                The manual has talks about a special plug you can get that goes in the spark plug hole that emits a gas that protects everyting.
                Acta Non Verba
                • mason79
                  • Mar 2006
                  • 1359
                  • los angeles, ca
                  for a good long term approach; ride it daily!!
                  History
                  85 Yamaha FJ 1100
                  79 yamaha xs1100f
                  03 honda cbr 600 f4
                  91 yamaha fzr 600
                  84 yamaha fj 1100
                  82 yamaha seca 750
                  87 yamaha fazer
                  86 yamaha maxim x
                  82 yamaha vision
                  78 yamaha rd 400
                  • nubee
                    • Jan 2006
                    • 206
                    • Fort Worth Texas
                    Hey Pat Kelly & HobbyMan,
                    Maybe this is the way to go:
                    Anti-Rust Motorcycle Storage Bag
                    Nubee
