I saw a do-it-yourself shop air compressor tip, and it kinda... expencive and complicated.
Here's what u do:
Get a compressor out of a refrigirator or sth similar... I'm sure you know where to find a dead fridge. Chances are, the compressor is still good. It's the black can-like thingie with a black box on the side and wires sticking out of the box and copper tubing going to wherever it goes.
These things are rubber mounted and usually just clamped on, so pulling it out shouldn't be a problem. Just bring pliers to cut the electrical cables and copper tubes.
All you need to do now is weld some adapters for your tools on the compressor. Test where it sucks air in and where does it blow out.
Caution... don't turn it on the side... it has some oil in it, and it should stay there.
Where the air is blowing out... you can connect that hose with a fire extinguisher or some sort of can, that can take some pressure. It's not necessary, but it helps a lot. Put on a psi meter, just in case... since these things don't turn themselves off automatically.
My kawa and car door were painted with a cheap toy-shop modeling air brush and a compressor as described above, and it worked great.
LP
Here's what u do:
LP
