Do you Winterize?
  • TADracer
    • May 2006
    • 1417
    • Kenner, Louisiana USA
    Do you Winterize?
    Here in South Louisiana I dont winterize because I manage to ride just about all year but I know it gets pretty chilly up North.
    So, how many of you guys winterize your bike? And, what do you do?
    Mike Giroir
    79 XS-1100 Special
  • cloerts
    • Mar 2007
    • 153
    • Tahlequah, OK
    nope
    It only freezes or snows a couple weeks out of the year, so i don't winterize anything. I just make sure to start all my engines twice a week and call it good. Of couse I'm not much farther north than you are.
    Casey
    1980 xs1100g "Frankenstein" (Now with a mind of his own!)
    "What do you mean I can't park this thing here?"
    "Shiny side up? I don't have a shiny side."
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      My fall oil change uses 10-40 Castrol GTX. My spring oil change uses 20-50 Castrol GTX.
      Summer I ride my LG with the cafe windshield. Winter I ride the E with the full touring fairing with lowers.
      That's the XStent of my winterizing. After all, I'm in California
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
      • planedick
        • Mar 2005
        • 2068
        • Yorba Linda, California
        Winter? What's that?
        In So Cal I ride most every day. How else can I do 18,000 mi/year?
        Drilled airbox
        Tkat fork brace
        Hardly mufflers
        late model carbs
        Newer style fuses
        Oil pressure guage
        Custom security system
        Stainless braid brake lines
        • prometheus578
          XS-XJ Super Guru (RESIGNED)
          • Aug 2004
          • 4012
          • Olympia , Wa.
          Hook the battery to a tender; drain the float bowls. Bike on center stand, block o' wood under the engine to raise the front wheel. That's about it.
          • 81xsproject
            • 3185
            • Fortuna, CA
            Only halfway. The weather gives random riding availablity everyonce in a while. So, I just add some fuel stabilizer and keep it on the tender.
            '81 XS1100 SH
            Sep. 12th 2015
            RIP
            • TomB
              • Aug 2006
              • 967
              • Cumbria, UK
              Honestly
              An old duvet and some dust sheets. My garage is in my house and doesn't go below 50 deg.F
              No battery charging, just started straight away after 6 months lay up
              Tom
              • EZMoney
                • Oct 2006
                • 115
                • Castlegar, BC,
                Battery out, oils all out and changed to fresh, fuel stabilizer in, set on center stand, block front wheel off the ground, cover and let stew in cold garage for four or so months or until done.
                Uncover, drain and refill bowls to remove any sediment, install battery, start and enjoy
                Ed
                Ed
                78/82 XS/XJ mostly made up of parts bikes
                XS1100 SG 1980 Will restore to original over time
                  5 months frozen in Saskatoon.
                  Bike stays in attached garage over winter.
                  Oilchange to el cheapo 10W30 automotive oil for the winter. Refill with 20W50 motorcycle oil and renew the filter before the spring startup. Battery stays in but hooked up to autocharger. Drain carbs. Drain gas tank & swish a cupful of engine oil around in it.
                  Fred Hill, S'toon.
                  • xswilly
                    • Jul 2003
                    • 462
                    • Hollis, maine
                    batt out, gas stabil in
                    centerstand
                    ft wheel up
                    air pressure down in tires
                    heavy coat of wax all over
                    spring
                    oil change first thing
                    sit from nov to may this year
                    see the temp thread to see why
                    http://home.securespeed.us/~xswilly/
                    79F Parts
                    80G Parts
                    75 DT 400B enduro
                    • Pain
                      • 476
                      • Milwaukee, WI
                      I ride all year, but change the oil before the first big cold snap, and again when it warms up, whether it needs it or not.
                      WD-40 all over the bike too, in the fall, and I don't wash it until spring.
                      I've been in more than one Hemisphere, and I wrote a book to help you do it too (or just prepare better for that week long road trip). Going Small, not just for the little guys.
                      • Pain
                        • 476
                        • Milwaukee, WI
                        Hmm,. this is was supposed to be in the Winterzie thread.
                        I guess I shouldnt post at work.
                        • midnight1980
                          • Mar 2007
                          • 312
                          • cedar city, utah
                          please dont use pax on it.. it will probley melt the metal of it LOL!
                            I hate my neighbor
                            While I have been carefully nurturing my XS11 in our attached heated garage the kid across the street abandoned his Honda CX500 to the full 6 month long savagery of a Saskatchewan winter at the back of his driveway. No cover, no gas inhibitor, he even left the battery in it. While I have been triple cleaning the XS11 carbs, charging it's battery and replacing it's sparkplugs to get it running I have gained comfort from the thought that the kid is going to regret neglecting his bike like that because it ain't never going to start after such treatment. Today I watched him turn on the gas, turn the key, push the starter button and have the bike fire right up.
                            There ain't no justice!
                            Fred Hill, S'toon.
                            • TADracer
                              • May 2006
                              • 1417
                              Re: I hate my neighbor
                              Fred Hill, S'toon.
                              Fred, the part you didnt see was him out in the driveway at 2:00 am in the snow triple cleaning his carbs and charging the battery just so he could impress you in the morning.
                              Mike Giroir
                              79 XS-1100 Special
