Hey folks,
Don't get too Xcited. My old badges were very worn from my extra long legs hitting against them on the tank. And since I've modded my bike considerably, I wasn't looking into replacing the OEM badges, but wanted to get some CUSTOM badges!
Regrettably, I don't have a CNC mill, so my efforts appear a bit crude, but with some black background paint, and a bit more time against the polishing wheel, and also a little heat to get it bent to conform to the shape of the tank, it should do fairly well for my purposes! So...here it is before I paint the background.
I already have a rotary table, it's what I use to mill out the SOFA in nice concentric circle paths. But it would have been a real pain to try to use it for this project, because I would have had to "try" to find the center of the arc for each corner of those letters, and reposition the workpiece for each one. Also, my rotary table can mount on my crosslide table, but I only have essentially the ways direction of movement....closer or farther away from the mill head, but NOT across the cross slide direction!
, imagine using a drill bit, but instead of a pointed tip, it is cut flat. It was only 1/8" thick, and it can cut on the end of it as well as it's side, it's an End Cutting Milling bit, just fairly small. The space between the letters is just a little over 1/8" wide. I'm able to use the mill like a drill press so I can raise it to position it over the work like for the center of the letters, press it down and it cuts/drills into the piece to the depth I set, and then I can move the piece in both X/Y directions to remove material beside the bit, like a wood router!
