Stump the Band!
  • jimboreeno
    • 427
    • Smithville, MO
    Stump the Band!
    OK Gurus, I have a (probably easy) challenge for you..
    I was riding the other day, nice weather, no rain or water.
    The XJ had been giving me some intermittant sputter so I ran a bottle of seafoam through. Great stuff. I was riding on the next tank of gas when the following happened.
    Riding along and got a big hiccup/sputter
    Didn't think too much of it then, wham BIG hiccup
    downshifted and increased RPMS ... ran better
    then WHAM a BIG power-loss hiccup.
    It recovered but I was afraid I was dead in the water (or on the side of the road as it were)
    Then I thought it through and fixed the problem without stopping the bike. It worked and I rode on with a big grin and LOTS or relief.
    Any guesses on what happened and what I did
    (There are probably lots of potential answers here, but I was so happy to figure this out I thought I would throw it up and see what you came up with!)
    JimBoReeno
    My Ex!"Half-Breed"
    '82 XJ1100 Maxim with
    '80 XS1100SG Motor
    Current Bike
    2000 Indian Chief
    Millennium Edition
    .. turned the petcocks back on....
      Had a loose connection at the kill switch or ignition switch?
      • jimboreeno
        • 427
        • Smithville, MO
        no on the petcocks
        no "loose" connections
        JimBoReeno
        My Ex!"Half-Breed"
        '80 XS1100SG Motor
        Current Bike
        2000 Indian Chief
        Millennium Edition
        • Dragonrider
          • 1219
          • Garland, Texas
          I'd check the battery cables...on the battery and the other ends, particularly the negative to the frame.
          Also main fuse holder, and the rest of the fuse holders too...particularly ignition.
          It really sounds like a loose ground somewhere.
          CUAgain,
          Daniel Meyer
            Choke still on?
            • jimboreeno
              • 427
              • Smithville, MO
              OK... John, you were the closest. It was not a loose connection, but... the rocker on the kill switch was somehow in the middle. It would make the connection with enough rpms but each bump would stall it out.
              I tried to reproduce it, to see if the switch was bad or going bad, but I could not make it do it again.
              When it originally happened it felt like it does when hitting the kill switch so first... I freaked out and worried , then all I did is switch to kill then back and it didn't happen again.
              This was a pretty easy one (John basically hit it on the 2nd reply) But I figure you gurus could throw out some good stumpers.! so...
              Stump the Band!
              JimBoReeno
              My Ex!"Half-Breed"
              '80 XS1100SG Motor
              Current Bike
              2000 Indian Chief
              Millennium Edition
              • HobbyMan
                MeatHead Idiot "GURU"
                • 1801
                • Colleyville, TX
                Lets get some more of these. You guys reply to quickly. I was in the garage "working"
                Acta Non Verba
                • prometheus578
                  XS-XJ Super Guru (RESIGNED)
                  • Aug 2004
                  • 4012
                  • Olympia , Wa.
                  "What he said."
                  Yeah, and I worked late and am two time zones away. Don't give the answer so soon!
                  • TADracer
                    • 1417
                    • Kenner, Louisiana USA
                    Hiccups......I was going to say have something different for lunch! But John guessed it too quickly.
                    Mike Giroir
                    79 XS-1100 Special
                      I had a similar condition some years ago...The housing on my ign switch had broken, and every now and then I would loose all power. I had to ride with one hand pressing down on the key to keep it running.
                      • jimboreeno
                        • 427
                        • Smithville, MO
                        Premature answerlation
                        You are right, I should have held out. The next one to throw one out there give it at least 24 hours before the answer.
                        JimBoReeno
                        My Ex!"Half-Breed"
                        '80 XS1100SG Motor
                        Current Bike
                        2000 Indian Chief
                        Millennium Edition
                        • HobbyMan
                          • 1801
                          • Colleyville, TX
                          Does anyone have any more? If not, I have one. It should be REALLY easy.
                          Went on a long ride on my 80G. Stopped back at the house to get a snack. On my way out of the neighborhood
                          (downhill road with a curve) , the two left cyls cut out, then the right. I had to push the bike home a up the hill. What happened, and what did I do to fix it? If you can't get this on your first try, I will be shocked and dissapointed. I will wait a while before posting the answer if you don't already know it.
                          Acta Non Verba
                            My guess is you ran out of fuel after the long ride, because you forgot to reconnect the fuel gauge wires, and forgot to switch to reserve. WK said that you may have not turned the fuel on, but you were probably riding the Standard, and it doesn't have an off position on the petcocks.
                            • Czekus21
                              • 1069
                              • Keosauqua (Southeast) Iowa
                              That was my guess as well. Ran outta fuel.
                              S.R.Czekus
                              1-big XS patch
                              1-small XS/XJ patch
                              1-XS/XJ owners pin.
                              Just do it !!!!!
