First really nice day in SE SD. Temperarture got up to the mid 70's so pulled out my favorite xs11 special for a little ride. Put the carbs on prime for about 5 minutes and the ole girl fired right up and ran like a dream. Took her down the rode a few miles a blew the cobs out of her and still running like a dream. Decided the ole girl could use a bath (first inkling that high pressure water can be a problem) but no she really needed a good cleaning. Riding down to the car wash I thought about my original special being pretty fussy about water and would cough and run rough for a mile or two till she dried out. I went ahead and cleaned her up and took my time drying her off so the wind would help dry the electrical up too. Spent plenty of time admiring how nice she looked too. Started her up, running on the outside cylinders! No problem, take her out on the road, get a little wind through her and dry her out, ten miles later still running on two cylinders. Spent yesterday pulling tank, checking coils and finding coil for 2-3 was bad or wet what ever the case was. Thank god I had another coil. Anybody else have a premonition you shouldn't before doing something and finding out the premonition came true?
Shouldn't but Did it Anyway!
DEW
One Red "Creation 1"
One Black"Creation 2"
One Black"Creation 3"
One ???? "Creation 4"
One ???? "Creation 5"
One ???? "Parts Bike"
All the above 1100 Specials
78 Standard (Ruf Ruf)
1980 Midnight Special
1978 650 SETags: None -
When I wash my bike I do it by hand and then rinse it off from above so I don't find myself directing a lot of water into areas when it isn't ment to go. Even while riding in a down pour, water usually does not get up under the tank where its not welcome.
RobKEEP THE RUBBER SIDE DOWN
1978 XS1100E Modified
1978 XS500E
1979 XS1100F Restored
1981 Suzuki GS1100
1983 Suzuki GS750S Katana
1983 Honda CB900 CustomComment
I had the same problem with MIYAMI. If it'll miss when you wash her, It'll miss when it rains and your riding. I put dilecric grease ( non-condictive ) on every electrical connection on the bike. Not just on the spade side of the connectors, but on every part of the connectors. Then fired her up and gave it the ol' garden hose test. Sprayed water in every orfice and crevis that I could find. No more spitting and sputtering.S.R.Czekus
1-big XS patch
1-small XS/XJ patch
1-XS/XJ owners pin.
Just do it !!!!!Comment
Pressure wash..
I use the local coin operated high pressure wash often. The '79 would miss for a little while after the ordeal, but Pathfinder don't care. High pressure everywhere, top to bottom, up under tank, etc and she never misses a beat. Fire her up drippen wet to get out of the spray booth and never misses at all.You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake linesComment
Just keep the pressure washers off the bearings. Anything else should take it. If it prangs your electrical, you've got work to do...'cause a heavy rain's gonna do the same thing. You should fix it first ('cause it sucks trying to fix wet electrical problems beside the road in the rain)Comment
Happened once to me in a rainstorm on my 78E. Started misfiring a little. First chance I had I took the coils out and I could see that the spark plug wires had a gap where they entered the coil. I covered the whole area with gasket material and never had a problem again.
Hard to believe rain can get up in there.Marty in NW PA
This IS my happy face.Comment
