After dealing with a shrinking redline due to a clutch that was getting worse as the miles went on, it was finally replaced with some help from Patrick (Succubus). Fibers and springs were replaced. All the fibers speced out within tolerance even with 68k on them. Clutch springs were way outa spec so I most likely could have gotton away with just springs. I used OEM plates and springs. A quick ride on Saturday proved a good fix but since I went out without my skid lid on, I didn't push it much. The front end once again get "light" when all the troops come on line.
On this mornings ride to work, I redlined 2nd and felt it slip.
Seems with the light mist on the road, it was the back tire breaking loose and not the clutch slipping, this was confirmed by the slight side shuffle of the back wheel when I did it a second time.
I LIKE IT!!!!!
Thanks again Pat for your help.
I LIKE IT!!!!!Thanks again Pat for your help.
