Its out
  • desert1
    • 750
    • Grand Desert, Nova Scotia, Can.
    Its out
    Well the motor is out of the 79 Special and sitting on the bike jack
    next pull out the 78 motor and install the specials. Mototrs are large when there outta the bike and in your face! Heavy as well, used a rope strung around my neck and on the other side of the bike on my brothers neck, lifted and pulled towards the bike jack.
    Bruce
    Bruce Doucette
    Phone #1 902 827 3217
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    i see guys on tv lifting v twins into choppers all the time, do our engines weight more? why?
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    • Ken Talbot
      • 4251
      • Revelstoke, BC
      Yes, our engines do weigh more. I've got one sitting upside down on my workbench in the basement and I know I'll never be able to move it back outside by myself. It was a bit of a struggle carrying it down the stairs with the cylinders, head, starter, final drive, and covers off. Those v-twins you see them installing have no transmission or clutch and a very small dry-sump crankcase.
      Somebody weighed an engine a while back, but I can't find the post.
      Ken Talbot
      • Wildkat
        XS Special Gurette
        • Apr 2004
        • 3416
        • Location, Location
        I found this thread
        Try this for engine weight
        It looks like DennyZ has it at 192 pounds... I didn't read the whole thread so weight may vary...
        81 SH Something Special
        79 SF MEAUQABEAUXS
        81SH Nor'eas tah (Old Red)
        80 LG Black Magic
        78 E Standard Practice
        James 3:17
        “Alis Volat Propriis”
        Yamaha XS 1100 Classic
        For those on FB
          Just bear hug 'em and have your way with them!.. lol. I think they are more awkward than heavy. Just make sure you use your legs and not your back as much as possible.
          • desert1
            • 750
            300 lbs.!
            I was just guessing with my Brother and figured 220 to 250 lbs. for the engine weight.....
            What we did to move it out was raise it clear of the frame with 2 automotive scissor jacks using 2 blocks of wood as a cushion, removed the filter as well then jimmied it to the right side of the bike onto an awaiting bike lifter with plywood for a base....now to clean it up and blow all the crud between the fins away.. remember this bike sat outside for 3 yrs in all weather but the engine sounds some smooth and quiet, cant wait to have it in my 78! Be nice to have that shiny engine gleem back but I dont know if there is a way to recoat the engine??
            Bruce
            Bruce Doucette
            • Ken Talbot
              • 4251
              • Revelstoke, BC
              Re: I found this thread
              Good find, Wildkat, I knew it was out there somewhere.
              Ken Talbot
              • Wildkat
                XS Special Gurette
                • Apr 2004
                • 3416
                It certainly SEEMS like 300...
                Especially when trying to move one by yourself...
                ahem...
                Bruce
                Not certain about keeping the original shiny... Several have painted theirs using a high temp paint... I used a caliper paint on my FJ engine that seems to be holding up very well... There was talk of clearcoating at one time but nobody (as I recall) had found a clear that didn't eventually yellow... I have found that an extremely high grit sandpaper or emery cloth (around 4000 grit) wrapped around a toothbrush works well between the fins... gets a lot of the dull out of them...
                Thanks Ken... I know my way around an engine... okay... a search engine... but an engine none the less...
                79 SF MEAUQABEAUXS
                80 LG Black Magic
                James 3:17
                For those on FB
                • Czekus21
                  • 1069
                  • Keosauqua (Southeast) Iowa
                  When I pulled the motor on MIYAMI to repair the frame, I figured that the motor/trans assy was about 175-200lbs. That was just a guess. My nephew and I man handled it out of the frame. Next time I have to pull one, I'll removed the oil filter cover,cam cover,starter. Main resons are for clearance and wieght.
                  When I pulled apart an XJ, I carried the engine assy myself from the frame to the ground, to the work bench, was then carrying it to it's storage spot and found out the hard way that ya don't hold onto the motor mount spacer on the front. It will come off. I dam near lost a foot when it hit the ground. Busted the oil pan.( Was full of oil ). A little awkward to carry.
                  S.R.Czekus
                  1-big XS patch
                  1-small XS/XJ patch
                  1-XS/XJ owners pin.
                  Just do it !!!!!
                  • desert1
                    • 750
                    Caliper paint?
                    Never heard of "caliper paint " Wildcat, will check out the local paint shops for that....thanks, Bruce
                    Bruce Doucette
                    • Wildkat
                      XS Special Gurette
                      • Apr 2004
                      • 3416
                      Auto parts stores
                      Check your local auto parts store... any of them that carry paint will more than likely have the caliper paint... It is supposed to be able to withstand high temps and most fluids and it's very durable and so far, at least on the FJ... it has...
                      Good luck and post pics!
                      79 SF MEAUQABEAUXS
                      80 LG Black Magic
                      James 3:17
                      For those on FB
                      • desert1
                        • 750
                        Will do
                        Will do Wildcat, easier to paint while the engines out. Will do some pics as well
                        Bruce
                        Bruce Doucette
                        • Ken Talbot
                          • 4251
                          • Revelstoke, BC
                          I'm getting ready to paint the engine on the 'winter project' bike I've been working on for the last couple of years. This past weekend, I picked up a low-budget engine stand like this one:
                          I figure I'll get extension tubes welded onto three of the adjustable mount points. This should let me mount the engine by its three sets of mounting holes. Then I'll be able to rotate it for cleaning and painting. All I need is a couple of buddies to help pack it up out of the basement when it warms up a bit more outside.
                          Ken Talbot
                          • andreashweiss
                            • 951
                            • 180 mile northwest of Spokane,WA
                            Motor should be the last part out of a bike frame. Take the oil filter assembly off.Tip the frame over either left or right and usually the ends up in your hands.
                            • desert1
                              • 750
                              Getin one
                              Ken, I'm goin to Princess auto after work and lookin to buy one of those motor lifters.....Excellent find Ken. Thanks for postin a picture
                              Bruce
                              Bruce Doucette
