Handy little detailing tip
    I recently decided to try and remove the flaky, oxidized plastic on an old front master cylinder reservior, as it was looking like the one on my bike, and I didn't want to sacrifice the one on my bike to be the ginea pig, in case I screwed something up.
    I clamped the reservior in a vise with cloth rag padded jaws, and worked it over with a coarse file until all of the oxidized material was gone. I then used a small pocket screw driver, and scraped out the flaky stuff from the depression where it is marked LOWER. After all that was removed, I used some 120 grit emory cloth and started sanding the reservior until the sides felt smooth, and the natural color returned to the plastic. I then went over it with some 320 emory cloth and just sanded away until I was satisfied with the finish. I then folded the emory cloth small, and worked it around in the depression until it was smoothed out. This whole procedure took about an hour. Your time may vary. The reservior cover was very faded also, so I practiced on an old one and stumbled upon a great resto tip. After a good cleaning with a toothbrush and brake clean, the cover still looked weathered, so I was trying to think of some way I could stain it, and make it black again. I thought about some liquid shoe polish. That may work. I remebered I had some black Rub n' Buff, so I tried that. I applied a small amount to the tip of a toothbrush and started to apply it. It covered well and adhered to the surface without streaking or smearing. I finished applying it and let it set a couple of minutes. The Rub n' Buff will not stain the DOT label on the cover, either. It just wipes right off. I rubbed the XS Rub n' Buff off, and it looked like a new cover! Nice deep, rich color. That with the refubished reservior really makes a noticible difference. I swapped out the reservior on my bike and while I was in there, I inspected the spooge hole, and removed the O ring that seals the reservior to the master. There was so much crap built up under the O ring that it had to be scraped out, an the O ring had to be replaced. Anyway, now the newly detailed pieces are on my bike and they look great. I no longer have that ratty, crumbly, embarassing reservior sitting next to my recently detailed switch pods, and new mirrors. That was the last item to be addressed on the bars, and it stuck out like a sore thumb. I had bought a new reservior a couple of years ago, but it I found out that it only fit a Standard, so I couldn't use it. Now we don't have to replace the reserviors. We can just refinish them.
  • webbcraft2150
    • Sep 2002
    • 1605
    • AUSTIN.TX
    Re: Handy little detailing tip
    [QUOTE]Originally posted by John
    [B]I, but it I found out that it only fit a Standard, so I couldn't use it. ]
    So, does that mean you have a spare new one that wil fit a standard? I do have a place for it.
    • Bauer
      • 269
      • Garrison ND
      Bauer
      1980 XS 1100 SG (The 3rd Degree) - The Cafe' Racer
      Image Photos @ http://photobucket.com/albums/f230/BauersXS11/
      1980 XS1100 G (The Trouble Maker)
      Fully stock and still goin at 65k miles
        Re: Re: Handy little detailing tip
        [QUOTE]Originally posted by webbcraft2150
        [B]
        Sorry Webb, but I sold it when I found out I couldn't use it.
        Ken Talbot was the first one to discover the difference. he had posted some pics showing the differences.
        I was just in the garage piddlin' around when I got the idea for it, and tried it, and I didn't think it would be worthy of taking pictures of at the time.
        • mason79
          • Mar 2006
          • 1359
          • los angeles, ca
          always take pictures for us visual types, like when i put a bicycle inner tube to replace the dry rotted speedo clock damper, looks stock , has a "suspension" and it's free!!
          History
          85 Yamaha FJ 1100
          79 yamaha xs1100f
          03 honda cbr 600 f4
          91 yamaha fzr 600
          84 yamaha fj 1100
          82 yamaha seca 750
          87 yamaha fazer
          86 yamaha maxim x
          82 yamaha vision
          78 yamaha rd 400
          • HobbyMan
            MeatHead Idiot "GURU"
            • 1801
            • Colleyville, TX
            ironic, thats how I replaced my damper. I do think that I will add this to my list of things to try.
            Acta Non Verba
            • Bauer
              • 269
              • Garrison ND
              Re: Re: Re: Handy little detailing tip
              Open mouth insert foot....
              Sorry John, I didnt mean to sound like the business end of a donkey when I posted that. The intel you gave us was well heeded, I just thought pictures would be a worty addition. If not of the process, at least of the after effects.
              Bauer
              • nate
                • Sep 2006
                • 116
                • PA
                So the reservoir comes out of the master?My master cylinder is leaking between the reservoir and base or whatever it goes into is called.
                1980 XS1100g
                  Yes, the plastic reservoir does separate from the body of the master cylinder. There's an o-ring down there.
                  • nate
                    • Sep 2006
                    • 116
                    • PA
                    Got it off.Cleaned up in there haven't seen any leaks yet.knock on wood.Wish i would have tried hard to get it apart when i had it off the bike.
                    1980 XS1100g
