Went for a ride down Ortega hwy yesterday. Was a freeway ride for about 30 mi then some twisties. While in the twisties between 45 and 60 MPH I noticed some loud noises from the engine. Understand, I wear a really tight fitting fully foam lined helmet which makes it hard to hear engine noises. It sounded like a rod was loose because it knocked when not pulling or holding back, right at the point where there is no load. So I went home on the old road kinda easy and noticed it was quiet at 45MPH but started knocking around 50 MPH. When I got home I put on my little half helmet and went for a ride, because I can hear everything with that one. It scared me so bad I was tempted to push it home before damaging it anymore.
Took off the fairing and got to work. Compression check, 100, 140, 140, 100. Not good but not too bad. #1 plug looked just right, 2 was showing white flakes, 3 likewise 4 black crusty flakes. Put them back in and started it up to check the timing. Timing was advanced as far as the mcechanical mount allowed. WAY TOO MUCH Set it with my timing light and went for a test ride. Much better, but now I can see the carbs are not balanced and I have to get a balancing tool before it will run right. I was borrowing one from a friend, but he moved away.
